F20B crank & rod's into H22A
Old Dec 9, 2007 | 07:35 AM
Mr.Milton's Avatar
Default F20B crank & rod's into H22A
would this raise my Rod-to-Stroke ratio..?if yes...would I be able to Rev it higher than with the stock H22 crank/rod's..?
Modified by Mr.Milton at 4:05 PM 12/9/2007
Old Dec 9, 2007 | 08:19 AM
Lubo_25's Avatar
Default Re: F20B crank & rod's into H22A (Mr.Milton)
h22a is 90.7mm, f20b i believe is 88mm someone correct me if i'm wrong just find the rod length it should be under the H/F specs on here theres a bad *** write up on all of the internals specs of these motors
Old Dec 9, 2007 | 03:07 PM
Mr.Milton's Avatar
Default Re: F20B crank & rod's into H22A (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">h22a is 90.7mm, f20b i believe is 88mm someone correct me if i'm wrong just find the rod length it should be under the H/F specs on here theres a bad *** write up on all of the internals specs of these motors
Sorry I asked the wrong question I meant Rod-to Stroke..
Old Dec 9, 2007 | 05:30 PM
Lubo_25's Avatar
yes it would raise your rod to stroke ratio h22a is 5.633/3.571=1.58:1, f20b i believe is approx 5.709/3.464=1.65:1 which will let you hang around the 9000 rpm range more comfortably but your powerband will be shorter in my opinion the h22a offers the best of both for torque and reliability but nothing wrong with the f20 combo either i will be adding a h22a crank to my f23 block soon for my g23 vtec combo...
Old Dec 10, 2007 | 12:33 PM
Mr.Milton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">yes it would raise your rod to stroke ratio h22a is 5.633/3.571=1.58:1, f20b i believe is approx 5.709/3.464=1.65:1 which will let you hang around the 9000 rpm range more comfortably but your powerband will be shorter in my opinion the h22a offers the best of both for torque and reliability but nothing wrong with the f20 combo either i will be adding a h22a crank to my f23 block soon for my g23 vtec combo...</TD></TR></TABLE>
H2B all the way!!
slvrcvc_9139
Apr 16, 2011 10:26 PM
slowboy90
Jan 28, 2010 06:46 PM
