new STAGE CLUTCH Question
Old Dec 9, 2007 | 02:59 AM
da9blk1's Avatar
Default new STAGE CLUTCH Question
hi i just picked up a stage act stage clutch and prresure plate. do i need a tob or can i use my stock one
i got a jdm b16 tranny thats pretty fresh.
thanks
Old Dec 9, 2007 | 03:05 AM
da9blk1's Avatar
Default Re: new STAGE CLUTCH Question (da9blk1)
Old Dec 9, 2007 | 03:21 AM
da9blk1's Avatar
can i use the stock one?
Old Dec 9, 2007 | 04:28 AM
da9blk1's Avatar
help
Old Dec 9, 2007 | 04:47 AM
da9blk1's Avatar
THROW OUT BEARING?
Old Dec 9, 2007 | 04:56 AM
da9blk1's Avatar
its a stage 2 sprung 6 puck clutch and heavy duty pressure plate
Old Dec 9, 2007 | 05:02 AM
non-VTEC's Avatar
it would be a good idea to used a new throw out bearing when installing a new clutch assembly.
usually when you buy a kit they supply you with one.
Old Dec 9, 2007 | 05:08 AM
da9blk1's Avatar
Default Re: new STAGE CLUTCH Question (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">it would be a good idea to used a new throw out bearing when installing a new clutch assembly.
usually when you buy a kit they supply you with one.</TD></TR></TABLE>
pmd
i bought it from some guy forgot to ask for it!
what are consequences from using stock...anyone doing it?
Modified by da9blk1 at 6:35 AM 12/9/2007
Old Dec 9, 2007 | 05:52 AM
da9blk1's Avatar
yelp
Old Dec 9, 2007 | 06:16 AM
da9blk1's Avatar
is the presure plate good?
do i need to resurface it...i dont want to if i dont have to i dont know what im suppposed to look for here are 3 pics:
Old Dec 9, 2007 | 06:31 AM
non-VTEC's Avatar
hmmmmmm.......either my screen is kinda crappy or the pics arent very clear but i think i see a bunch of blue/black hot spots on that pressure plate....i hope you got that clutch pretty cheap and dont be suprized if you get some chattering during engagment.......but you will never know until you install it.
as for re-surfacing the pressure plate.......i dont think it would be cost effective...you might as well just buy a new plate........or better yet buy a whole new clutch kit.
Old Dec 9, 2007 | 06:54 AM
da9blk1's Avatar
clutch was brand new...isnt it only 20$ to resurface...what are hot spots?
Old Dec 9, 2007 | 06:58 AM
da9blk1's Avatar
are hotspots bad....
what do the cause?
Old Dec 9, 2007 | 07:56 AM
non-VTEC's Avatar
who told you that clutch was brand new? that does not look remotly close to a new pressure plate
hot spots are caused by excessive slipping/dumping the clutch. even if you can get someone to machine that pressure plate for you chances are it will be under spec since they have to machine quite a bit to get the blue/black hot spots out......and if they machine too much you will not get the proper clamping load on the disc and then it will just slip constantly......
take better pictures of the pressure plate surface so we can get a better look at it.....also take pics of the disc.
Old Dec 9, 2007 | 08:01 AM
turbociv910's Avatar
that clutch isnt brand new, you got ripped off.
if it was brand new, shouldnt it be clean.. did you miss all the dust and dirt on it?
i wouldnt even worry about fixing that, like he just said, it will slip.
go buy a new one. How much did you buy that one for?
there are no hassles with using a stock TOB, their better than the ones ACT provides you with.
Old Dec 9, 2007 | 08:15 AM
da9blk1's Avatar
Default Re: new STAGE CLUTCH Question (turbociv910)
bigger...the lighting keeps messin it up
like i said i bought a new clutch with a "lightly used" PP.
Old Dec 9, 2007 | 08:21 AM
non-VTEC's Avatar
ohh i see.....the disc is new......the plate is used.........hmmmm.......i would just slap it it.......as long as the pressure plate surface is not cracked it will work.
you will get chattering regardless of the pressure plate surface since its a ceramic disc. Ive never driven one that engaged smooth to begin with.
Old Dec 9, 2007 | 08:23 AM
da9blk1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">ohh i see.....the disc is new......the plate is used.........hmmmm.......i would just slap it it.......as long as the pressure plate surface is not cracked it will work.
thanks man
no cracks just a lil discolored.
so its good to install. thanks!
ya the disc is new sorry about the confusion
da9blk1's Avatar
oh ya i payed 140.
thats how much that disc is new on advanceclutch.com
so either way i didnt get ripped
Old Dec 9, 2007 | 10:01 AM
og asr's Avatar
Make sure you get some sandpaper and sand the surface of the pressure plate (try to get those hot spots off).......then get some brake cleaner and thoroughly clean all oils off of pressure plate before installing.....
For $140.00......that's a good deal.
If you are too cheap to get a new throw out bearing....just check to make sure your old one is not wobbly and feels pretty snug.
If you really want to do this right...change the pilot bearing as well on the flywheel.
Old Dec 9, 2007 | 04:44 PM
DC2Hedi's Avatar
damn pilot bearings are hard to get out with out a grease gun :'(
Old Dec 9, 2007 | 08:00 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: (DC2Hedi)
use a socket and hit the socket with the hammer and hammer in the piolt bearing very easy
Old Dec 10, 2007 | 07:04 PM
gen2fanatic's Avatar
Default Re: (DOHCgarage919)
I'd never buy a used clutch assembly. And you ALWAYS want to replace the throw out bearing and pilot bearings while you got it out. Thats the last thing you want to do is to have to pull it all back out again just because you took the cheap route...
Ive never heard of anyone resurfacing a pressure plate anyway, only flywheels.
DC4_Dad
Transmission & Drivetrain
Oct 15, 2014 05:12 PM
onefastegg
Feb 28, 2008 08:50 AM
