ABS rotors
Old Dec 9, 2007 | 12:55 AM
TiGASNANGULO's Avatar
Default ABS rotors
Is there a difference between the ABS and Non ABS brembo blank rotors? Because i just purchased a pair and I told them I had ABS but i later found out that I don't have it. Thanks in advance.
Old Dec 9, 2007 | 10:51 AM
BlueIntegraBoy's Avatar
Default Re: ABS rotors (TiGASNANGULO)
Well, it depends. ABS rotors are 10.25" in diameter (ie Integra, Civic EX ABS, Del Sol VTEC), but non-ABS rotors can also be 10.25" (ie Civic EX, 99-00 Civic Si). If you have a Civic EX or 99-00 Civic Si, you can use either rotor as ABS/non-ABS is not dependent on rotor size.
Old Dec 9, 2007 | 11:09 AM
I have a 93 civic SI, will it still fit?
Old Dec 9, 2007 | 11:16 AM
Default Re: (TiGASNANGULO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiGASNANGULO &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 civic SI, will it still fit?</TD></TR></TABLE>
Nope, you have 9.5" front rotors. Rear, ABS or non-ABS, are all the same and will fit.
SIcivicHATCH
11
Jan 22, 2016 12:12 PM
alexb18c1
Jul 10, 2008 04:04 AM
2wheelhunter
May 6, 2007 07:33 PM
mr abstract
Dec 27, 2006 10:48 AM
slow94coupe
Jan 13, 2005 08:28 AM
