rear disc brake swap. use eg6 ebrake cable?
Old Dec 8, 2007 | 09:29 PM
tekstyle's Avatar
Default rear disc brake swap. use eg6 ebrake cable?
hello, I have changed the rear caliper before on an integra, but never on a civic. i just remove the pin that holds the cable to the spring loaded caliper. is it the same way on the eg6? i can get a conversion from an integra, but it doesn't come with the cable.
also, i thought drum brakes are not hydraulics. or am i wrong?
Old Dec 8, 2007 | 09:32 PM
Luserkid's Avatar
Default Re: rear disc brake swap. use eg6 ebrake cable? (tekstyle)
I dont get what your asking.
And i dont believe they EVER made a brake system that wasnt hydraulic for civics.
Old Dec 8, 2007 | 10:57 PM
tekstyle's Avatar
Default Re: rear disc brake swap. use eg6 ebrake cable? (Luserkid)
i read somewhere that the ebrake cable are of different length and for a integra to civic rear disc swap to work, u need the integra cable.
however, the position of the caliper and drum are gonna be at the same location so shouldn't I be able to use the same cable when i do the swap?
that is what i am asking. thanks man!
Old Dec 8, 2007 | 11:56 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">i read somewhere that the ebrake cable are of different length and for a integra to civic rear disc swap to work, u need the integra cable.
that is what i am asking. thanks man!</TD></TR></TABLE>
the rear caliper on a civic and integra are the same. replacing the caliper and cable will take the same steps.
as for the cable, they are all the same. ranging from 92-00 civic and 94-01 integra.
i believe the 90-93 integra are slightly different, but the rear trailing arm and brakes are the same.
and for the drums, yes they are hydraulic, always have (that i know of).
Old Dec 9, 2007 | 12:00 AM
fmrprojects's Avatar
Default Re: rear disc brake swap. use eg6 ebrake cable? (philosofy1)
you need integra brake cables
Old Dec 9, 2007 | 01:03 AM
tekstyle's Avatar
Default Re: rear disc brake swap. use eg6 ebrake cable? (fmrprojects)
so whats the verdict? i hear nay and yay to integra brake cables... i hope i don't need them.
Old Dec 9, 2007 | 08:07 AM
project93cpe's Avatar
i just put gsr rear discs and yes you need integra 94- 01 e-brake cables or 92-95 si e-brake cables, you need them.
Old Dec 9, 2007 | 11:30 PM
tekstyle's Avatar
Default Re: rear disc brake swap. use eg6 ebrake cable? (project93cpe)
thank you project.
Old Dec 10, 2007 | 01:40 AM
DCSportEJ1Civic's Avatar
yes rear drums are hydraulic. the only thing that isnt is the parking brake itself.
vtec4eternity
Aug 24, 2009 07:58 PM
turboblack2door
Apr 30, 2009 03:18 PM
rick_rabies
Feb 12, 2009 06:23 PM
aeboync
Dec 30, 2006 10:16 AM
chhuong
Jan 30, 2003 11:11 PM
