Anybody good with chipping ECU's? Quick question-
Old Dec 8, 2007 | 06:18 PM
vestalfootball72
Guest
Posts: n/a
Default Anybody good with chipping ECU's? Quick question-
Hey guys- I recently chipped a P75 ecu a while back but now its showing a solid CEL (sign of a bad ecu)
Does everything look normal?
Old Dec 8, 2007 | 06:56 PM
mike1jag's Avatar
Default Re: Anybody good with chipping ECU's? Quick question- (vestalfootball72)
is there a resistor missing to the left of the chip socket? other than that every thing looks ok
Old Dec 9, 2007 | 06:14 AM
vestalfootball72
Guest
Posts: n/a
Default Re: Anybody good with chipping ECU's? Quick question- (mike1jag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1jag &raquo;</TD></TR><TR><TD CLASS="quote">is there a resistor missing to the left of the chip socket? other than that every thing looks ok</TD></TR></TABLE>
No theres a capacitor that goes into C52 to the left of the socket-
This chip set is different then the phearable one below though- There is no R54 location, so i left it blank after being recomended to by phearable-
Old Dec 9, 2007 | 10:39 AM
DC4 Dave's Avatar
It sounds silly, but make sure your chip sits snugly in your ZIF socket, and the socket fits snugly into the ECU. I had this problem a few times, turns out my chip would actually start to slip itself out of the socket and the instant one pin left contact, limp mode and a solid CEL.
Double check all your connections, and plugs coming from the chassis wiring harness into the ECU.
Old Dec 9, 2007 | 10:54 AM
vestalfootball72
Guest
Posts: n/a
Default Re: (DC4 Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4 Dave &raquo;</TD></TR><TR><TD CLASS="quote">It sounds silly, but make sure your chip sits snugly in your ZIF socket, and the socket fits snugly into the ECU. I had this problem a few times, turns out my chip would actually start to slip itself out of the socket and the instant one pin left contact, limp mode and a solid CEL.
Double check all your connections, and plugs coming from the chassis wiring harness into the ECU.</TD></TR></TABLE>
Thanks Dave- The car ran good no CEL before, but then after chipping this problem occured- I went through all connections and still had this issue. So then I took out J1, to see if it would work again like normal, and still had the solid CEL-- So what possibly could have happend? I did a clean job on this one, and didnt burn the board or at least that I could possibly tell...
Could it be that I at first sucked out the solder out of R54? Does their need to be solder in the blank holes for it to work properly? Thanks guys-
Old Dec 9, 2007 | 11:00 AM
DC4 Dave's Avatar
Default Re: (vestalfootball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">
Could it be that I at first sucked out the solder out of R54? Does their need to be solder in the blank holes for it to work properly? Thanks guys- </TD></TR></TABLE>
Hmmm ... it's an ECU issue, I can say that much. Check to see if your fuel pump is turning on - if it isn't, there's a resistor in backwards. My buddy chips ECUs, and this happens every now and again. Double-check the direction of all your resistors, and it should work.
Old Dec 9, 2007 | 11:15 AM
vestalfootball72
Guest
Posts: n/a
Hmmm ... it's an ECU issue, I can say that much. Check to see if your fuel pump is turning on - if it isn't, there's a resistor in backwards. My buddy chips ECUs, and this happens every now and again. Double-check the direction of all your resistors, and it should work.</TD></TR></TABLE>
The car will start, but it just runs like hell-
I dont think its the chip however, as ive burnt and tried many different ones--
I have reason to believe its the ECU because after cutting J1 it still ran like hell-
Old Dec 9, 2007 | 11:16 AM
vestalfootball72
Guest
Posts: n/a
Also Dave- What is the proper way for the resistors to be installed? thanks
Old Dec 9, 2007 | 12:49 PM
vestalfootball72
Guest
Posts: n/a
turns out the Q31 is blown--
I know this is bc of switching out wiring harness plugs, but could it be related to chipping the ecu??
SkoundrelUSA
Jul 19, 2006 04:47 PM
FortunateFool.
Jul 10, 2005 07:03 PM
vtecpower2000
Nov 11, 2003 10:25 AM
Zer0DazE
Jul 2, 2002 07:54 AM
hatchmobile
Apr 25, 2002 06:15 PM
