'97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help
Old Dec 8, 2007 | 03:19 PM
weavertime1's Avatar
Default '97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help
I am sure this has been answered before, but I have a '97 Accord with an H22a Euro R engine in it. It also <U>HAD</U> the Euro R ecu in it using an OBD2A to OBD2B jumper harness. This ecu would start the car, but it would run horrible (hardly enough power to gt it moving). I decided since I live in NE PA, and we are an emissions-testing free area (for now), that I would use an chipped OBD1 ecu with an H22A basemap and of course the proper jumper harness from OBD2A to OBD1. Now the car runs much better, but the idle stays at 1500 rpms and quickly goes back and forth between 1500 rpms and 1700 rpms. Obviously I am thinking there is an IACV issue seeing that the ecu is looking for a two wire IACV and the euro R's is a 3 wire. What are my options here, and is there a way to wire my three wire plug to be a two wire, because putting a two wire IACV is a PITA on the Euro R manifold from what I have read. If you have seen this before, just post the link and that would be greatly appreciated. If you have knowledge of it yourself, please let me know asap!
Old Dec 8, 2007 | 07:56 PM
Default Re: '97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help (weavertime1)
up!
Old Dec 9, 2007 | 03:15 AM
Ovrbst_T66's Avatar
If you search on here there is a good thread on this with pics ,i will try to find it for you.
Old Dec 9, 2007 | 07:15 AM
Default Re: '97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help (Ovrbst_T66)
I figured there would be, but I tried searching, and I couldn't get anything under the topics I searched for. Thank you for the help in advance!
JayWest's Avatar
PM user Rosko on here
He makes an adapter to use the correct IACV on the euro-r manifold
Old Dec 10, 2007 | 07:22 PM
KidFrost's Avatar
Default Re: '97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help (JayWest)
bump... i have my reasons
hi c dubya
Old Dec 10, 2007 | 08:01 PM
ESP.net's Avatar
Default Re: '97 Accord with H22A Euro R running chipped OBD1 ecu IACV wiring help (KidFrost)
I am guessing your using a p28 chipped ecu?
Rosko and Collective both sell the adapter plates for your stock Accord 2 wire I believe IACV
If not running EGR you will need to plug the EGR ports at the flange of the Euro R or you will have a bad vacuum leak which causes idle fluctuation...
OBD1 injectors are needed...
Old Dec 12, 2007 | 06:59 PM
OK...here are the codes I got:
10 - Intake air temperature sensor
14 - Idle air control valve
22 - V-TEC pressure solenoid
I was pretty sure about the IACV, and I am guessing since the car was a non-vtec special edition, that the previous owner did not wire the vtec right...but the IATS is strange? Anybody done one and had the same issues? Thanks
Old Dec 12, 2007 | 07:40 PM
KidFrost's Avatar
thats it ?/
i figured there would be a **** load of codes..
thats good... you have wired vtec before and the iavc shouldnt be that hard ... so really just one.. i have been looking around sorry i cant help
bump for you tho..
Old Dec 13, 2007 | 11:25 PM
97LXF20B's Avatar
did you do your own wiring on the swap? do you know what wiring harness changes were made?
i would recommend fixing all the other stuff before worrying about vtec.
is your IAT plugged in?
do you currently have the 3-wire iacv plugged in and running? if so - the third wire is just a ground... you should be able to splice the other two wires into the 2-wire iacv plug from a usdm accord or prelude harness and use Rosko's adapter kit to run the accord/prelude 2-wire iacv.
also:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 injectors are needed... </TD></TR></TABLE>
x2
Old Dec 14, 2007 | 03:01 AM
Default Re: (97LXF20B)
The car actually runs and drives right now, it just idles very strange, and stutters and such. I appreciate the help on the IACV. I am planning to order the adapter and IACV this weekend. In terms of the injectors, I do not understand how this would make a difference? Can you please explain this to me? As long as you use the normal injectors with the resistor box like all accords and preludes use, switching between OBD1 and OBD2 should not make a difference. could you show me some more information on that if possible? Thanks!
Old Dec 14, 2007 | 12:15 PM
Default Re: (weavertime1)
Bump!
Old Dec 14, 2007 | 05:58 PM
97LXF20B's Avatar
I don't know exactly... I know my obd2 accord has no resistor box - I think that might be obd1 and obd0 only... but not sure. the clips are also different.
Old Dec 15, 2007 | 08:43 AM
Ok...I am down to this:
IACV CEL...and the adapter is on order from ROSKO RACING. I just need to find a 2 wire H22 or H23 IACV. I will post a want to buy thread, but if anyone that views this has one in the NorthEast (so I don't have to wait 5 days for it) please hit me up.
VTEC and IAT issue solved:
I did not know that many JDM engines only have one wire going into the vtec mechanism, and therefore no vtec pressure switch. Therefore the USDM ecu was looking for the pressure switch and it wasn't there, which of coursethrew a CEL. I jumped A4 and D6 near the ecu to solve this issue. Here is the link: https://honda-tech.com/zerothread/1693528
I can't exactly explain the IAT issue, except for when I did the wiring change from the 3 wire IACV to the 2 wire IACV it must have somehow eliminated the CEL for IAT as well. Does this make sense to anyone?
Anyway...I hope to get the adapter from Rosko Racing by the middle of this week and have the car finished so I can sell it to KidFrost before Christmas! Thank you to anyone who has provided information so far.
Old Dec 15, 2007 | 12:20 PM
97LXF20B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">
not sure what mods were done to your wiring harness, but some of the sensors do share voltage sources and/or grounds on my harness... I do not think the IAT and IACV share wiring, but who knows? if they do share wiring on your harness then you may have bypassed some short in the process of doing your splicing.
best of luck!
Old Dec 15, 2007 | 02:33 PM
ESP.net's Avatar
I am still curious which ECU are you using?
Far as I know if you arent using the EGR you will have a vacuum leak unless you plug the 4 EGR ports on the manifold at the flange...
Old Dec 15, 2007 | 06:58 PM
KidFrost's Avatar
Default Re: (ESP.net)
he is running a chipped p28
Old Dec 15, 2007 | 07:22 PM
Default Re: (KidFrost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KidFrost &raquo;</TD></TR><TR><TD CLASS="quote">he is running a chipped p28</TD></TR></TABLE>
P72 jack *** ...and the egr is hooked up, but I do not know if the ecu is even reading off of the EGR plug? It has an H22A basemap, thats all I really know.
Old Dec 16, 2007 | 10:28 AM
KidFrost's Avatar
really i thought you said p28.... my bad DAWG
Old Mar 26, 2008 | 09:38 PM
dnyce20's Avatar
i have the same f20b using single cam vtec 97 accord ex harness having problems with dist, knock sensor and iac valve single cam harness 2 wire f20b harnes 3 wires,dist 8 wires single cam harnes 6 wires, wat to do please help d
dointhemzs
Nov 12, 2008 12:37 PM
weavertime1
Apr 15, 2008 04:24 AM
weavertime1
Dec 30, 2007 07:57 PM
KaRiZMa
Jul 14, 2004 03:04 PM
