20-21mpg... and im tuned
Old Dec 8, 2007 | 10:14 AM
RNbuilt's Avatar
Default 20-21mpg... and im tuned
cruise afr is 14.5-15.3
will a clogged fuel filter alter the fuel pressure? my pressure is pretty much the same, but im thinking my pepboys purolator fuel filter is hurting me...
Old Dec 8, 2007 | 10:25 AM
RyanA's Avatar
Default Re: 20-21mpg... and im tuned (NAB18CR)
IF your AFR is there, you are good at cruise. If your WOT AFR looks good as well (not overly rich), you may just be getting that because your engine uses that much fuel. Good WOT AFR also tells you that you don't have a fuel system problem. Keep in mind that all motor cars do get worse gas mileage since they are making the power all the time.
jakem200
Apr 29, 2009 06:03 PM
JDMKid71
22
Mar 11, 2006 08:57 AM
Pengo
Jun 11, 2003 08:43 PM
ThatRicerDaniel
Jan 28, 2003 04:08 PM
teamimpulse
May 20, 2002 10:01 AM
