Thermal Exhaust Question
I have the Thermal Axel back connecting to my factory b pipe which I believe is 2.5 inches. The thermal is 2.25 and I am getting the 2.25 comptech 4-2-1 header put in as well. Will I loss power with the inconsistency of the sizes from the header to the exhaust? The great header test with the comptech 4-2-1 was also placed on an exhaust with 2.5 inch piping and still performed excellent. Will I gain similiar numbers or am I better off getting a 2.25 in B pipe made? Thanks!
[Modified by SMSP, 5:08 PM 6/26/2002]
That's a hard one to answer. It depends on the type of resonator/muffler you use, how the joints are made in the tubing, cat vs. test pipe, accuracy of the test, etc. I thik the Comp Tech did well due to the stepped test pipe and the exhaust. I think the results might be different if it was dumping into a 2-1/4" cat and then 2-1/2" tubing.
SMSP - Who still thinks if your modding a B18VTEC engine it should include a header with a 2-1/2" collector
Well, if I stayed with my factory b pipe and cat, installed the comptech 4-2-1 header, and also have the thermal axel back exhaust and AEM CAI, would I be making at least 10-12 whp?
Austin - who does it at times as it's easier to say some things
