clueless.... b16 ef
Old Dec 7, 2007 | 08:35 PM
nelzef9's Avatar
Default clueless.... b16 ef
after driving my car for a while about 30 min the car starts to bog, hesatate when i try to open it up u hear the vtec pop and everything it does it aty like 6000rpms and no check engine light right im clueless need sum advice wut do you guys u car drives fine when i dont stomp on it .. it just started it like a week ago............
Old Dec 8, 2007 | 07:09 AM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: clueless.... b16 ef (nelzef9)
does it do it all the time or only Sometimes . . ?
check the plugs and wires or i should say get new ones
my car did the same thing. Got new NGK V-Power plugs and NGK wires and called it a day
Old Dec 8, 2007 | 12:28 PM
nelzef9's Avatar
Default Re: clueless.... b16 ef (x4thGenCafe)
after i drive the car for a while like a good 30-40 min drive it will do it everytime i try to punch it at like 6grand tho from 1 -5 grand it drive perfect
Old Dec 8, 2007 | 02:05 PM
OF THE KINGS
hmmm.
either do what i told you and if that doesnt work you might wanna try changing the fuel filter . . other than that , I honestly have no clue
Hows the distributor ?
Old Dec 8, 2007 | 04:11 PM
91EF9hatch's Avatar
might want to check your sensor on your throttle body? i had this problem once and i replace spark plug/wire and that wasnt it so i recheck all wireing and sensor and found out it was my sensor not working right.
JDMmadness
Feb 18, 2010 01:43 PM
Daniel jdm
12
Jun 17, 2009 08:36 PM
jermcramp1
Mar 19, 2008 01:55 PM
soundfx06
Jan 16, 2008 03:24 PM
97_delsol_Vtec
May 6, 2006 10:12 PM
