Innovative Motor Mount Kit For 94-97 Accord With H23 or F20B Swap
Ok i just want to let you guys know, that a friend and myself swapped a H23 motor into his 95 Accord. I figured that all H-series motors were the same so we ordered the kit for the H22 motor. Come to find out that the only mount that fit was the tranny mount. The reason the rear and driver side mount didn't fit was because, the mounting brackets on the H23 are different from the H22.
After finding this out, we called innovative to let them know what was happening, and they are pretty much bending over backwards for my friend. They had us send them back the mounts that didn't fit, along with the stock factory mounts that way they can make the correct mounts for him.
Now they already have the rear mount made so they didn't have to make it. Just to give some info on the rear mount, there are 2 different rear mounts with the 94-97 accord. There is a 4-bolt rear mount and a 3 bolt rear mount. Whichever ones you cars uses you will have to specify that, if you ever order mounts from them.
Now innovative didn't make a front mount for this kit, but my friend wanted it also, so they agreed to make the front mount also for him. So we shipped them a stock front mount also.
Basically my friends car is the prototype for this kit, so in the near future like in 2 weeks you will be able to order this kit from innovative for the F20/H23 motor swap. Also even if you don't have this swap this same kit will fit with the stock motor thats already in the car also.
Right now we have the rear and side mount, we are just waiting for innovative to complete the front mount. Once we get it i will tak epics of the mounts an dpost them here before we put them in the car, and i will take pics of how the motor sits once we install them.
2 thumbs up to innovative, for being so helpful and actually taking the time to help us.
On a side note:
I do not work for innovative, nor am i trying to boost sales for them. Im just posting up my experience dealing with them, and i just wanted to pass the info that there is a full motor mount kit available for the 94-97 Accord now. Swap or no swap.
On a side note:
hi looking all overfor info on f22b or h23 swap in 96 accord ex. cnat find much at all can you help thnx
I have a h23 in my car right now. would I have to buy a motor mount kit to put a f20b in there? I have a 4th generation prelude. any info would be more that amazing. thanks. this is also my first post!!
After a couple nightmares I had with other swap companies - I'd only deal with innovative from this point forward. Most recently I was dealing with problems with aftermarket mounts for f series into an ek - when i dropped the money on the innovative mounts - ill never go back...too easy.
se93
Jul 18, 2002 03:49 PM
