lowering a 96 hatch
Old Jun 26, 2002 | 03:17 PM
LiLn81224's Avatar
Default lowering a 96 hatch
what would be the easiest way to lower my car say 2-3 inches or so?? just getting lowering springs, or coilovers?? what exactly is the difference between those two anyway?? sorry its a dumb question but i new....thanks
Old Jun 26, 2002 | 03:30 PM
BenB's Avatar
Default Re: lowering a 96 hatch (LiLn81224)
If you want to do it right. Get new coilovers and shocks. I just got my Skunk2 coilovers and Tokico shocks.
Old Jun 26, 2002 | 04:09 PM
-Gambit-'s Avatar
Default Re: lowering a 96 hatch (BenB)
the difference between a spring and a coilover is a spring is none adjustable which means you can not adjust how high or low you want your car.
Old Jun 26, 2002 | 08:39 PM
LiLn81224's Avatar
Default Re: lowering a 96 hatch (gambit33)
are R1 coilovers any good?? also, how low can i go before having to adjust the camber?? thanks
Old Jun 26, 2002 | 09:00 PM
-Gambit-'s Avatar
i personally wouldnt buy r1 coilovers, i would stick to ground control or skunk2. and as far as camber kits, its a good idea to get one if you even lower your car an inch just to save your tires
Old Jun 27, 2002 | 12:18 AM
Evs-One's Avatar
Solbros Owns Me
actually, the suspension type on most Hondas IS a coilover type if you want to get technical. It means the coil is over the shock. You really mean adjustable spring pirch...sorry to get so serious...but getting the adjustables is always best, especially if you do lots of different driving, especially winter driving...
I wouldn't get Skunk 2's- every car I've been in with them, either slammed or stock height, is really bouncy and can't handle corners very well. I personally like the Tien HA's or the Apex N1's. Both are a completely adjustable setup with spring to shock matchness. They're about 850-1300 though.
[Modified by Emerica, 9:21 AM 6/27/2002]
Old Jun 27, 2002 | 07:40 AM
cre18's Avatar
i'm dropped about 2 1/2 inches on ground controls and tokico illuminas. with coilovers, you have the ability to adjust the height of your ride to whatever you like. also, i would suggest a camber kit and an alignment after you have found your desired height.
Old Jun 27, 2002 | 11:13 AM
Vic Nyce's Avatar
Default Re: lowering a 96 hatch (Emerica)
my friend has Skunk2 adjustables and KYB AGX struts. very bouncy. I rode an integra with progress true coilovers and i was very impressed. smooth over bumps and great on turns. true full coilovers.
Old Jun 27, 2002 | 11:42 AM
kmf0211's Avatar
Default Re: lowering a 96 hatch (Vic Nyce)
my brother has Tokico 5 way gas shocks....... seem to get the job done well!
ALso - when i purchase my coil overs...Probally going to be ground control or Skunk2....how do i go about adjusting the height?
Old Jun 27, 2002 | 11:58 AM
-Gambit-'s Avatar
Default Re: lowering a 96 hatch (Hatch_92)
to adjust how low you want your car to sit with coilover, there is a ,little threaded collar that you just to turn and it will make the spring higher or lower
Old Jun 27, 2002 | 01:33 PM
XchtmgX's Avatar
i have skunk2 coilovers they handle great but if you still want the stock ride i heard that ground controls ride nice
lowtegsr
Suspension & Brakes
10
Jun 10, 2008 02:55 PM
BigPlansNoMoney
Nov 9, 2004 09:31 AM
03ephatch
May 20, 2004 10:13 PM
Boostless-Lude
Oct 26, 2003 09:13 AM
Typerc716
Jul 31, 2001 04:53 AM
