Built B16a2 engine for boost MAKE OFFERS
I have a Mint b16a2 engine forsale only about 4k miles on it since it was rebuilt
I bought this engine from one for the mods at HMT.com he had it built.
Its just sitting in my garage and need it gone.
Make some offers but i will not respond if its a lowball offer
block:
-b16a2 block
-oem honda water pump (less than 4k miles)
-oem honda oil pump (less than 4k miles)
-oem timing belt (less than 4k miles)
-oem tensioner (less than 4k miles)
-oem main and rod bearings (new)
-oem rear and main seal (new)
-wiseco 8.8:1 pistons (81mm bore) (less than 4k miles)
-eagle h beam rods (less than 4k miles)
-wiseco rings (new)
-alternator
-intermediate shaft
-tapped oil pan
-oem oil pick up (less than 4k miles)
-oem crank pulley
-arp head studs
head:
-b16a2 head
-skunk 2 cam gears (less than 4k miles)
-gsr cams
-fresh valve adjustment
-vtec solenoid and all sensors
-stock intake manifold and throttle body
-stock fuel rail
-b&m fpr
-stock injectors (if you want them)
-valve cover cut for cam gears
-new oem valve cover gasket
-ngk bkr7e-11 spark plugs (less than 2k miles)
Located in Cocoa Beach Fl near Port Canaveral
block:
-b16a2 block
-wiseco rings (new)
-alternator
-intermediate shaft
-tapped oil pan
-oem crank pulley
-arp head studs
head:
-b16a2 head
-gsr cams
-stock fuel rail
-b&m fpr
r1de23
Jul 15, 2009 06:30 PM
TannerCB
May 25, 2007 04:54 AM
TannerCB
May 14, 2007 03:39 AM
