Rim trouble...(BBS)
Old Dec 7, 2007 | 11:42 AM
SBlimeDC2's Avatar
Default Rim trouble...(BBS)
so i purchased these of a fellow ht member...bolt pattern is 4x100 +25 offset....now im having trouble because the lug bolts on my 2000 gsr are comming up to short....
what do i do?????
here are the rims....(before) now their stripped, repaired and polished..
Old Dec 7, 2007 | 12:21 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: Rim trouble...(BBS) (SBlimeDC2)
You could get some extended wheel studs...
Old Dec 7, 2007 | 12:25 PM
VTEC_PRODUCTION's Avatar
Default Re: Rim trouble...(BBS) (Byaaah!)
word! or modify the rim somehow...changing wheel studs are a bitch on the front. i dont know about that back. havent changed those out yet...but if i were you i would get the wheels machined if you can have someone do that favor for you...otherwise get ready for a load of fun replacing wheel studs...
Old Dec 7, 2007 | 12:35 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
How are they too short? They don't stick far enough through the holes in the rim? So like the center part of the rim is really thick or something?
That sounds odd. If you machine any material off of the wheels, you'll end up with a higher offset. Judging by the +25 offset I'm assuming you bought those on purpose because you're going for that "low-offset look", which of course would be defeated if you machine any material off of the wheels.
Wow that's crazy, I've never heard of lug studs being too short to even fit through the holes in the wheels.
Good luck with that. Dunno how those will look on a newer Integra, those being more "old school" wheels and all...
Old Dec 7, 2007 | 01:28 PM
SBlimeDC2's Avatar
Default Re: (PatrickGSR94)
yeah their a little short....they stick out a bit...but not enough for my lug nuts to screw on
Old Dec 7, 2007 | 06:11 PM
lickety_britches's Avatar
what is the 'offset'?
Old Dec 7, 2007 | 08:05 PM
SBlimeDC2's Avatar
Default Re: (lickety_britches)
25
Old Dec 8, 2007 | 01:58 AM
shake_em's Avatar
what size are the rims? They might be hitting the brake caliper so it seams like the studs are short, and if you change the studs its not that bad at all, a good whack and they come out.
Old Dec 8, 2007 | 02:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Rim trouble...(BBS) (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">or modify the rim somehow...changing wheel studs are a bitch on the front.</TD></TR></TABLE>
Do not cut corners and try to modify the wheel. I don;t want to see a "My Studs Pulled Through My Wheel" threads. If the studs are too short, change them. There is a tool called a hub tamer that can pull the hub for easy stud change.
https://honda-tech.com/zerothread?id=1996133
Old Dec 8, 2007 | 08:30 AM
SBlimeDC2's Avatar
Default Re: Rim trouble...(BBS) (Dogginator)
15/7
Old Dec 9, 2007 | 03:14 PM
all you need is extended wheel studs
I stated that in my for sale thread
You can either do that or shave the inside center faces down (I believe called center bore)
There is a shitload of material left to be able to do that w/ them cracking
Old Dec 9, 2007 | 03:31 PM
CB's Avatar
CB
Default Re: Rim trouble...(BBS) (vega_ROCKS)
thats wierd man, i have a 98 gsr and my wheels have the same offset, bolt pattern, wheel width and zero problems. I'm lovin' the old school wheels though.
Old Dec 9, 2007 | 03:40 PM
Default Re: Rim trouble...(BBS) (CB)
the center bore on these wheels is hellA thick
Thats the only reason he has having a issue w/ the lugs
But its a easy fix
Old Dec 9, 2007 | 03:53 PM
Community Builder
ohhhh wait, so the center bore is too small? If that's the case, it's not even fitting over the hub, which is the problem.
Better get a GOOD machine shop to do it. You need to either make the hub exactly match a stock Integra wheel, or have them machined larger and use a hub adapter ring.
Either way it's probably going to be expensive, maybe even more than the price of the wheels.
Old Dec 9, 2007 | 04:05 PM
wait hold on.
what exactly is the center bore??
Is the center bore how the center face of the back end of the wheel lines up to the hub
or
how thick the back end of the face of the wheels are??
In the case the later is the problem he is having
The wheel clear the brakes fine is the thickness of the back face of the wheel that is thich which cause a short amount of wheel stud to peak through.
SBlimeDC2's Avatar
ill check out some shops on monday...for now...heres what they look like...just got them back from boltons classic wheels and are freshly sprayed!!
Old Dec 9, 2007 | 04:08 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (vega_ROCKS)
The center bore should be 64 mm for the OPs car. The wheels use that bore to align on the hub.
Old Dec 9, 2007 | 04:11 PM
Default Re: (Dogginator)
when all else fails...draw a pictures
Thats what I'm about to do
Old Dec 9, 2007 | 04:21 PM
Old Dec 9, 2007 | 04:24 PM
SBlimeDC2's Avatar
pictures are great...
im gonna try extended wheel studs....what size do i need???
Old Dec 9, 2007 | 04:41 PM
SBlimeDC2's Avatar
Default Re: (SBlimeDC2)
Old Dec 9, 2007 | 04:53 PM
integrajdm82's Avatar
whats up people
Old Dec 9, 2007 | 04:59 PM
it really doesn't matter what size
The extended stud will be fairly longer then then Stock stud by no comparison
Old Dec 9, 2007 | 05:05 PM
SBlimeDC2's Avatar
Default Re: Rim trouble...(BBS) (integrajdm82)
trying to get theses wheels on... i never knew it was going to be this hard!
Old Dec 9, 2007 | 09:01 PM
CB's Avatar
CB
make it work somehow man, those are sooo sick.
