What OEM rims fit the 94-97 Accord?
Ok I've searched and searched and searched and keep getting different answers. I'm new to the Accords, I picked up a 94 EX with some 17" rims on it. I want to pick up a set of OEM 15" rims for winter.
Now when I look on websites like discounttire.com, etc it says my bolt pattern is 4X100 but when i read in some of the forums, etc they say 4X114.3. So my questions are:
1. Which bolt pattern is it?
2. What other year accords will fit my 94.
3. Also will prelude rims fit? I found these off a 92 Si there 4X114.3
Any info would be great, just need a straight answer...hehe.
4x114.3
90-93 Accords - All
94-97 Accords - All
98-02 Accords - 4cyl
92-96 Preludes - All
yes, I had a set of those on my 95 EX before after I broke one of my EX rims.
90-93 Accords - All
94-97 Accords - All
there is one more set of OEM (JDM) Honda wheels that will fit: JDM 96 Spec Integra Type R rims (they look like a 15" version of Civic HX rims, in Championship White with red "H"s on the center caps).
i've picked up a set for my sister's 94 Accord; going to slap those suckers on one day when she's asleep, just for fun
just thought i'd throw that in as an alternative OEM wheel since no one else mentioned it already
Thanks!
To top things off, I keep trying to find another set of wheels, so about 2 hours ago I slam into a pot hole bent and cracked my front left drivers side rim. Ughhh
also, if you are looking for rims, there is a for sale thread for 4x114.3 rims...
https://honda-tech.com/zero...age=1
jump to the last pages for the most recent sale posts
Yeah i was thinking 205/55/15. I picked up a set of factory 15 rims cheap and the tires that are on it are plus zero 185/65/15. I set them next to the car and yeah, defantly be tucked...so I'm not sure how much of a difference size 60 is to 65.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90daXsi »</TD></TR><TR><TD CLASS="quote">...so I'm not sure how much of a difference size 60 is to 65. </TD></TR></TABLE>
depends on the width of the tire. thats just a percentage of the width.
On my 92 Prelude Si rims for my 95 Accord EX I believe I went with 205/55/15 but that was some time ago so I may be wrong.
Look at the rim, somewhere on it, it should be stamped with the diaXwidth (Ex. 15x5.5) and the offset (Ex. +55).
Your stock tire diameter should be 24.2" so whatever tire you go with try to keep the overall diameter close to that.
If you need help on understanding tire specs or how to calculate the overall diameter, check out the tech section on tirerack.com
http://www.tirerack.com/tires/...h.jsp
Sherif
Apr 28, 2017 09:39 AM
jay322
Jan 2, 2010 11:21 AM
