Air/Fuel Gauge
Old Jun 26, 2002 | 02:10 PM
2K1NBGSR's Avatar
Default Air/Fuel Gauge
Ok, i'm wiring up my Autometer Air/Fuel gauge in my 01 gsr. I just need to know which wire to hook up to by the ECU, for the O2 sensor. (Color/ Pin #)
TIA
Old Jun 26, 2002 | 02:32 PM
Aaron M's Avatar
Default Re: Air/Fuel Gauge (2K1NBGSR)
OMG i was just about to create a thread like this, i really need to know also. right now i have it connected to the o2 sensor on the header, but i dont feel comfortable with wires running all over my engine bay. does anyone know what wire it is on a odbII ecu? it seems like everyone has a odbI ecu, thanks
Old Jun 26, 2002 | 02:44 PM
2K1NBGSR's Avatar
Default Re: Air/Fuel Gauge (SilverB18C1)
well, i have an ECU pin-out and a wiring diagram, and i remember hearing from somebody that it's a solid white wire. and on the diagram, it shows a solid white wire going from the Primary 02 sensor to the ECU, and all the other wires on the primary O2 sensor, go to other sensors, so i'm pretty sure this has to be it.
Can anybody back me up on this?
Old Jun 26, 2002 | 02:59 PM
Aaron M's Avatar
yea i heard it was the soild white wire on the 3rd connector or something, once im off work ill try it out, and ill let you know how it goes
Old Jun 26, 2002 | 04:01 PM
IgniteTeg's Avatar
cool keep us updated i'm interested also. But i was runnin mine on my o2 sensor also and not really comfortable with it wires runnin around hehe
Old Jun 26, 2002 | 05:41 PM
tuco_ruiz's Avatar
i just put in my a/f gauge last week, and it's the big solid white one. it's not hugh but u can tell it apart. i think the pin is d14( don't qoute me on that)
Old Jun 26, 2002 | 06:52 PM
Aaron M's Avatar
Default Re: Air/Fuel Gauge (tuco_ruiz)
your right tuco_ruiz its the only solid white wire on the ecu, its on the BLUE connector, the one closest to the passanger seat. and i can tell a difference between wiring the guage from the sensor on the header and directly on the ecu. the ecu is much more stable when it moves, its a lot more consistant. i definatly recommend wiring directly to the ecu.
so basically for the ODBII ECU the o2 sensor wire is the solid WHITE wire on the blue connector. actually the ONLY soild white wire going to the ECU
Old Jun 26, 2002 | 07:47 PM
00VTEC's Avatar
what brand Air/Fuel Gauge are you guys using?
Old Jun 26, 2002 | 07:51 PM
Aaron M's Avatar
Default Re: Air/Fuel Gauge (00VTEC)
im using autometer
Old Jun 26, 2002 | 07:54 PM
tuco_ruiz's Avatar
autometer
Old Jun 27, 2002 | 09:00 PM
IgniteTeg's Avatar
Autometer
Old Jul 22, 2002 | 04:17 AM
metal-x's Avatar
Default Re: Air/Fuel Gauge (IgniteTeg)
I installed my A/F autometer gauge yesterday and I had no luck with the white wire with the red stripe which was the only one
I have an ODB1 and I ended up using the orange/black wire can anyone verify this to be correct for ODB1 cars?
Old Aug 2, 2002 | 01:02 PM
Integra_Boi's Avatar
New User
Default Re: Air/Fuel Gauge (metal-x)
well i have obdII and the solid white wire on the blue connector didn't work... so i'm gonna try that other "solid white wire" to the third connector now...
Old Aug 2, 2002 | 01:22 PM
Audi A4's Avatar
Default Re: Air/Fuel Gauge (Integra_Boi)
its a green wire. i think ppurple auto meter to integra green or white.
Old Aug 2, 2002 | 04:19 PM
mugenracer's Avatar
orange/black is correct, its the 4th wire in
Old Aug 2, 2002 | 05:47 PM
IgniteTeg's Avatar
Default Re: Air/Fuel Gauge (mugenracer)
lol so which wire is it from obd2 ecu?
Old Aug 2, 2002 | 06:46 PM
LOwrestling2001's Avatar
its the ONLY white one. there are white ones with stripes thats not it, there are white ones with like light silver dots those aren't it either, its SOLID WHITE. SOLID. i'm using the autometer on my 98 gsr so i'm positive .
Old Aug 2, 2002 | 08:17 PM
New User
Default Re: Air/Fuel Gauge (LOwrestling2001)
thats right lowrestling.. i finishhed wiring.. its actually not on the BLUE CONNECTOR.. its the gray one.. the last one on the right when lookin at it.. it sthe SOLID white without ne other colors on it...
Old Aug 2, 2002 | 11:25 PM
IgniteTeg's Avatar
Cool guyz thanks for the info btw, any of you have pic of how that solid white wire with gray connector look like? Actually I just want to see your wiring how you guys hide it and how clean was your install and stuff thanks.
Old Aug 3, 2002 | 12:22 AM
willie_su2166's Avatar
go http://www.apexi.com, then go apexi timer documentation. the diagram H-6 or H-2 then you got what you need.
sik_tC
Oct 23, 2008 02:17 PM
vtecb20coupe
Oct 6, 2004 05:02 PM
SHhh__VTEC
Apr 11, 2004 12:18 AM
speester1
Mar 29, 2003 11:05 AM
slknv
Jun 18, 2001 09:33 PM
