*Shift Lock*
Hey I have a 1994 Integra. I can't get it out of park unless I put the e-brake on and put my key in that slot. Help please!
Modified by murray195 at 12:18 AM 12/7/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murray195 »</TD></TR><TR><TD CLASS="quote">Hey I have a 1994 Integra. I can't get it out of park unless I put the e-brake on and put my key in that slot. Help please!</TD></TR></TABLE>
is it an automatic?
if its automatic then yes u have to put the key in
is it an automatic?
its automatic ?
if the car isnt on or the key isnt in the III position then u cant put it into gear.
but if u put the key in the shift lock slot next to the gears then yeah itll come out without havign to turn the car on.
It's an automatic and when the car is running you can't take it out of park even if you depress the brake. You have to put a key in the shift lock right next to the shifter
o so when the car is on, it still doesnt come out of gear? you HAVE to put it in the keyhole next to the shifter then start it?... um, have u tried holding ur brake pedal down while the car is on haha. cuz i mean, automatics when u put it in gear u have to hold down the brake pedal to get it into gear
unless seomthing is wrong with ur car then idunno,
what u can do is put it into N then u can start the car.
Like I said, even if I depress the brake, I can't move it into gear. Maybe theres a fuse somewhere between the shifter and break that's shot so the car thinks the brake isn't being depressed. I have a feeling it has something to do with a safety feature gone wrong but don't know where to start.
when you car is @ idle. and you press the brake pedal down to movie it out of park. you can and should hear a switching sound. If you do hear it, your saftey feature (forget the name) is working properly. If you don't hear it, check out the sensor. I think its located near the foot pedals. Might be a fuse too that goes to it.
Right on, been doing some more research and from the replies and what i've read it sounds like the sensor or the fuse. Hopefully thats it, I'll keep you guys updated. Thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb »</TD></TR><TR><TD CLASS="quote">
--... check out the sensor...
--... Might be a fuse too... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murray195 »</TD></TR><TR><TD CLASS="quote">sounds like the sensor or the fuse.</TD></TR></TABLE>
--- I RULE!
--- I RULE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R »</TD></TR><TR><TD CLASS="quote">Wow JDM_CRX_PLEASE isn't exactly the brightest person out there.
To the OP, check the sensor at the brake pedal. It's a button kind of sensor that should sense when you're pushing the pedal.</TD></TR></TABLE>
to both
to both
Well I finally got time to work on the integra. It was simply the fuse to the horn strangely enough. Shift lock is now taken care of however I'm having issues with the brake lights... they aren't coming on. All fuses are good including the switch under the brake pedal. hmm...
i have mx5 and same thing
new fuse new bubls and as far as i can see every thing works but wont light up when i brake
cars behind me honk when i "seem to slow down" out of nowere with no brake lights..
have u recently removed your tail lights?? do u have a brake light on?? when i painted my teg i removed the tail lights and when i bolted them back in a forgot to plug them in lol leading to this problem haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii »</TD></TR><TR><TD CLASS="quote">i have mx5 and same thing
cars behind me honk when i "seem to slow down" out of nowere with no brake lights..</TD></TR></TABLE>
thats bad your going to get rear ended and its going to be your fault
i know
there is nothing i can do
i cut the cables and they look good
for 16 year old cables
so i got new tailights, same looking ones not those ugly altezza,
and of course new wires and i connected them together, nothing
im scared
im scared
may not be much help. but try and replace all your brake lights. they should be only about $5-$!0.
i had a car once, came in paid for 1hr diagnostic, no brake lights, the writer was ready to sell them a brake switch, when all it was, was that all the bulbs were burnt out.
Sorry I took so long to get back to this posting. My front wiring harness was damaged and the horn wasn't working. I guess it caused a short. Anyways, long story short, made a harness from scratch for the sigs and horn, replaced the fuse, replaced a tail light bulb, and now its all good
Solo2Vtec
Oct 8, 2003 12:10 PM
