need help
Old Dec 6, 2007 | 09:56 AM
PnoyJeff's Avatar
Default need help
okay guys i have a problem , ive changed my dizzy , alt , wires plugs. battery is good timing is good , i still have a problem ... car will die after driving it for a couple of minutes . seems to drive fine but when i get to a stop sign the lights just kinda dim and the car just stalls ... and i think its only when the car starts to warm up ... any suggestions? thanks in advanced...
Old Dec 6, 2007 | 10:00 AM
97Ej6mike's Avatar
Are all your connections tight? No loose wires anywhere? Also, sometimes if water gets into a dizzy assembly, it can cause it to die off like that.
Old Dec 6, 2007 | 10:02 AM
NOman0608's Avatar
Default Re: need help (PnoyJeff)
any check engine light? ground wires? loose wires? clogged cat? maybe?
Old Dec 6, 2007 | 12:43 PM
crazyguy's Avatar
Default Re: need help (NOman0608)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOman0608 &raquo;</TD></TR><TR><TD CLASS="quote">any check engine light? ground wires? loose wires? clogged cat? maybe?</TD></TR></TABLE>
+1
Old Dec 6, 2007 | 12:46 PM
fmrprojects's Avatar
Default Re: need help (crazyguy)
check the cnnections on the battery and see that they are not corroded and loose. if not check your fuel pressure. if the car looses fuel preesure when warmed up, might cause it to die. just hook up a gauge and let it warm up andsee if the pressure drops
Old Dec 6, 2007 | 04:44 PM
blk92_d16's Avatar
AutoZone alernators are known to be crappy...where'd you get yours?
Old Dec 6, 2007 | 08:38 PM
PnoyJeff's Avatar
i got the battery from advanced, its new so no corrosion , grounds are good , new dizzy , i just changed the fuel filter but i should check the pressure... it started acting up when i changed my tranny oil .. do ya'll think it could have anything to do with that , to much oil , not enough? im open to all suggestions to keep my car from dying
thanks guy
Old Dec 6, 2007 | 08:40 PM
slo_hatch's Avatar
Default Re: (PnoyJeff)
fuel pump still good? maybe clogged injectors? or loose ground somewhere you cant find...it has happened alot.
Old Dec 6, 2007 | 10:02 PM
ejoner's Avatar
Default Re: (slo_hatch)
+1 on grounds. Make sure every single one of them is tight and corrosion free.
Old Dec 6, 2007 | 10:03 PM
PnoyJeff's Avatar
i might have to check my injectors? is there anything that i can buy/use to help clear them what do ya'll recommend
b18cEK
Nov 5, 2006 06:17 PM
Geiro94rs
Nov 11, 2004 11:01 AM
rs
Sep 22, 2003 07:50 PM
