1994 Civic Si HB- With rear disc brakes
I'm looking online for rotors and brakes, specifically, brembo oem replacements rotors and hawk hps brakes pads for the above car and after about a half hour of searching, I can't find OEM replacement rear rotors. At this point, I'm assuming that any 1994 Civic SI Hatchback with rear discs have been converted to such. With that said, I have the following questions:
What is the most common rear disc conversion done to a 92-95 SI Hatch? Integra rear disc?
What ways can I determine what conversion was done?
Would be much appreciated if anyone could answer these questions. I don't have a vast knowledge of hatch and I've done quite a bit of searching but a lot of information doesn't specifically give the answers I'm looking for. BTW, it's for one of my friends and is suppose to be a gift. Freaking x-mas bs...lol.
http://weaksauceparts.com/store/home.php?cat=1620
i cant remember where i saw brembo rear discs, but its a start
Rear discs were an option on the Si's and EX's (perhaps other models, too, but not sure). I've got an EX and have rear discs. I am pretty sure that EG/EJ ABS discs are the same as DC brake set up, so you will not gain anything from a DC swap. Also, any Autozone or local auto parts stores should be able to get you the rear discs.
Autozone rear disc
Autozone rear disc
Rear discs were 100% standard on all 1992-1995 Si hatches.
The part numbers are exactly the same as any 1994-2001 Integra RS/LS/GS-R - all except ITR.
The answer is buy parts listed for an Integra non-ITR and you'll be fine.
Also 1994 Si hatches did have an option for ABS, but the rear discs are 100% the same for non-ABS or ABS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Rear discs were 100% standard on all 1992-1995 Si hatches.
Also 1994 Si hatches did have an option for ABS, but the rear discs are 100% the same for non-ABS or ABS.</TD></TR></TABLE>
Ah, it was the ABS that was an option. My bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut »</TD></TR><TR><TD CLASS="quote">
Ah, it was the ABS that was an option. My bad.</TD></TR></TABLE>
No biggie - you were spot-on with the other stuff.
There used to be this huge debate about which years for the Si HB had ABS as an option, and people swore that 1995 is included, but it was, in fact, only 1994.
A fun thing to do to confirm this is call your local Honda dealership and tell them you need an ABS wheel sensor for your 1995 Si hatch - they won't be able to find it, or they'll say "are you sure it's not a 1994, because I can't click on it under 1995, but 1994 it does."
My 92 si has the orange plugs on the harness, i thought they were for abs, like maybe it was an option in japan and they just used the jap harnesses in 92 idk. My 94 ex with rear drums doesn't have these plugs on the harness
..worthless info I guess
</TD></TR></TABLE>My 92 si has the orange plugs on the harness, i thought they were for abs, like maybe it was an option in japan and they just used the jap harnesses in 92 idk. My 94 ex with rear drums doesn't have these plugs on the harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznsmtboy »</TD></TR><TR><TD CLASS="quote">Thanks for the help. BTW, is the suspension setup the same too?</TD></TR></TABLE>
Shocks, springs, control arms, trailing arms, etc. all bolt up to any 92-95 Civic from any 94-01 Integra.
You just can't mix and match rear ITR parts with non-ITR parts as the ITR has different rear lower control arms and shocks than the non-ITRs. ITR rear stuff bolts on all together on any 92-95 Civic though.
HtC_SiR
Northern California (Sales)
Jan 28, 2013 11:33 AM
blackjdmEKcivic
Oct 21, 2004 02:15 PM
