Brembo Sport Brakes
Brembo Sport Brakes
I just baught 2 Front and 2 Rear Drilled/Slotted Break Rotors & Pads.
Says its a direct bolt on, direct fit.. but is there anything im goin to need to get the most outa the breaks?
But these are both Disk plates, and my rears are Drums.
Plus it came with Zinc Plated.. so should I keep my OEM breaks for winter cuz road salt would eat the zinc wouldnt it?
Heres the Item:
Modified by waterboy at 11:29 AM 8/14/2005
Heres the Item:
Re: (waterboy)
find either a 92-95 civic ex, civic si or del sol si with rear discs, or a 94-01 teg and take the whole assembly off the rear, if u search i believe there is write up on removal/installation
Re: (waterboy)
https://honda-tech.com/zerothread?id=641639
btw it helps if you always check the archived too cuz there was a bazillion pages of this stuff
it comes with a 90day warrenty from Brembo USA
edit: just did research
Says
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Brembo rotors, cross-drilled/slotted in USA by SportBrakes</TD></TR></TABLE>
And the company's name is Sports Brakes, as is the same type of Bembo Brakes (Brembo Sports Brakes)
Says
I thought brembo only offered their rotors in either drilled or slotted, and not both on a rotor. Plus, the real brembo drilled or slotted rotors are Bronze in color, not silver, like their OE replacement rotors. If you got it from ebay, its most likely redrilled to resell as "performance" brakes.
Re: ([civic])
they sold them as
"Brembo SportsBrakes Slotted/Cross Drilled Free Shipping"
and the info says:
"Brembo Break Rotors Drilled by SportsBrakes USA..."
so basically they sold it as a real brembo brandname.. but it was actually their company name
http://cgi.ebay.com/ebaymotors...%3AIT - the item
APPLICATIONS:
90-01 Honda Civic EX
99-00 Honda Civic Si
Please verify the YEAR/MAKE/MODEL of your car for FASTER shipping
YOU ARE BIDDING ON 2 FRONT AND 2 REAR BRAND NEW BREMBO DRILLED/SLOTTED OE BRAKE ROTORS AND ONE FRONT/ONE REAR SET OF PBR METAL MASTER HIGH PERFORMANCE BRAKE PADS W/ LOW DUST
- CROSS-DRILLED/SLOTTED
- SAME SIZE AS YOUR STOCK ROTORS, DIRECT FIT
- NO MODIFICATION REQUIRED, PLUG AND PLAY
- FULLY COMPATIBLE W/ STOCK BRAKE PADS, LINES, CALIPERS, AND WHEELS
- FREE ZINC PLATED ($30.00 VALUE), FOR RUST PREVENTION
- DISPERSES GASSES, CLEANS PAD FOR BETTER "BITE"
- CNC MACHINED FOR PRECISION AND BALANCE
- CHAMFERED EACH DRILL PATTERN
and the info says:
APPLICATIONS:
Re: (waterboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waterboy »</TD></TR><TR><TD CLASS="quote">they sold them as
and the info says:
so basically they sold it as a real brembo brandname.. but it was actually their company name</TD></TR></TABLE>
Right, its an oe replacement rotor from Brembo, but redrilled by Sportbrakes USA, a different company.
and the info says:
Re: ([civic])
well is the OE replacement good?? i needed new pads anyway and my rear drum is rusty as hell.. prolly coulda just cleaned it up...
Brembo OE replacements work good for a basic street setup, along with good pads. I paid $60 for 2 Brembo blanks from nopi.
Search for "cracked rotor" on HT or the internet. You will find that crossed drill rotors tend to crack.
OG triple OG
Re: ([civic])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [civic »</TD></TR><TR><TD CLASS="quote">]I thought brembo only offered their rotors in either drilled or slotted, and not both on a rotor. Plus, the real brembo drilled or slotted rotors are Bronze in color, not silver, like their OE replacement rotors. If you got it from ebay, its most likely redrilled to resell as "performance" brakes.</TD></TR></TABLE>
yep brembo does not offer cross drilled and slotted on the same rotor
Re: (waterboy)
im betting the front dont fit either, because you ordered them for a car that had rear disk which means the front are probably 10" or 10.??" and since you have rear drum you probably have 9.?" front disks
Re: (d.maczko)
its got a garantee fit plus 30day warrenty...
doods got a 99.7% positive feedback on ebay & is a powerseller...
cross fingers for me
Suspetise...
1 Post
Re: (waterboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waterboy »</TD></TR><TR><TD CLASS="quote">its got a garantee fit plus 30day warrenty...
cross fingers for me </TD></TR></TABLE>
How do you hope to install rotors if you don't know the difference between drums and discs? Of course they'll fit...if you had disc brakes in the rear. If you don't, and you have drum brakes (which you do) how could they possibly hold a guarantee like that? Would you trust your life with such work, because that's what it'll come down to with brakes. And spending $250 on a set of rotors...yikes. Good luck I guess, cause you'll sure need it.
