Timing Issue with D15B8/D16Y8 Mini Me
Old Dec 6, 2007 | 06:16 AM
Dasfinc's Avatar
Default Timing Issue with D15B8/D16Y8 Mini Me
Car has a miss/stutter in low revs, and not a ton of power, Dizzy is a non-vtec B8 Dizzy *Bolts right to the Y8 head, but was told this would be fine*, Mechanical timing is dead on, I've replaced the coil/cap/rotor/plugs/wires and the problem remains
My IAT is mounted off a Vac Line also, but I was told this shouldn't cause problems like this, any other input?
I've heard rumors that I have to get an adj. Cam gear because of the setup, and because my head has been milled.
Old Dec 6, 2007 | 12:48 PM
97grnrs's Avatar
Default Re: Timing Issue with D15B8/D16Y8 Mini Me (Dasfinc)
im pretty sure when u mix a 1.5 bottom with a 1.6 top u need a adjustable cam gear. because of diff deck height or something. i built a few of them using z6 head and i used a cam.. especially if its decked . it may look close but its usually off 1/2 of a tooth which u cant adjust without the cam
Old Dec 6, 2007 | 01:22 PM
Dasfinc's Avatar
Default Re: Timing Issue with D15B8/D16Y8 Mini Me (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure when u mix a 1.5 bottom with a 1.6 top u need a adjustable cam gear. because of diff deck height or something. i built a few of them using z6 head and i used a cam.. especially if its decked . it may look close but its usually off 1/2 of a tooth which u cant adjust without the cam </TD></TR></TABLE>
Thats what I'm leaning toward, but noone has any definitive proof on this.
Old Dec 6, 2007 | 04:09 PM
97grnrs's Avatar
i did a few and everyone needed it so im sure yours will be the same. 1.5 and 1.6 have diff deck heights
Old Dec 6, 2007 | 05:16 PM
kiddcarbuff's Avatar
i woulda tried to find a b7 block, the b8 has tiny *** pistons and i think i rread in the mini me faq that it wasnt a good choice
Old Dec 6, 2007 | 06:16 PM
Dasfinc's Avatar
Default Re: (kiddcarbuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">i woulda tried to find a b7 block, the b8 has tiny *** pistons and i think i rread in the mini me faq that it wasnt a good choice</TD></TR></TABLE>
Just so you know, the D15B7 and D15B8 are the exact same block Sans the 8 valve pistons in the D15B8 *Which means you CANNOT do a MiniMe swap on it*
My B8 is one of the early-year oddballs that came with 4 valve pistons, meaning it is 100% identical to B7's
Old Dec 6, 2007 | 06:34 PM
97grnrs's Avatar
Default Re: (Dasfinc)
i did a mini me on the 8 valve block once and had no clearance problems. the two indents per piston only .
Old Dec 6, 2007 | 08:14 PM
Dasfinc's Avatar
Default Re: (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i did a mini me on the 8 valve block once and had no clearance problems. the two indents per piston only . </TD></TR></TABLE>
Thats VERY odd, I've been told there are interferance issues with that.
Old Dec 7, 2007 | 02:17 PM
Black-Ty [EG6]'s Avatar
im having timing issues with my mini me
i have a jdm d15 vtec block and d16y8 head
cant seem to get it timed.
also what IM u using?
y8 or the d15b8 one?
so i have to get an adjustable cam gear?
Old Dec 7, 2007 | 02:22 PM
Dasfinc's Avatar
Default Re: Timing Issue with D15B8/D16Y8 Mini Me (Black-Ty [EG6])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 &raquo;</TD></TR><TR><TD CLASS="quote">]im having timing issues with my mini me
so i have to get an adjustable cam gear?</TD></TR></TABLE>
I'm using a D16Y8 Intake Manifold *OEM Honda one, Manual with the IACV*
and I suspect Thats what we may both need.
D15B8 Intake manifold is the size of a lawn mowers, so I threw mine out, I had a B7 as a tested, which also works.
Old Dec 7, 2007 | 04:29 PM
damn it lol
i might as well jus use a z6 block then
Old Dec 7, 2007 | 04:52 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 &raquo;</TD></TR><TR><TD CLASS="quote">]damn it lol
i might as well jus use a z6 block then</TD></TR></TABLE>
Definatly not, the B7/B8 block generates a MUCH higher CR than a normal Z6 block does, and a AEM gear is only $60ish shipped off Fleabay.
Old Dec 8, 2007 | 12:45 PM
97grnrs's Avatar
u can find a cheaper cam off ebay. .i forget the name but i used it before. and ya u both need the cam if u want it timed exactly right. anytime u mix 1.5 and 1.6 heads and blocks u need one.
Old Dec 8, 2007 | 03:12 PM
am i gonna need to chip my p28 to handle the higher CR?
Old Dec 8, 2007 | 03:16 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 &raquo;</TD></TR><TR><TD CLASS="quote">]am i gonna need to chip my p28 to handle the higher CR?</TD></TR></TABLE>
To my understanding if you get it chipped you can make better use out of it, but really just running better fuel is all you need.
Old Dec 8, 2007 | 03:20 PM
o aight.
bigger injectors? or what?
Old Dec 8, 2007 | 06:03 PM
97grnrs's Avatar
i think he means goin from 89 octane to higher
Old Dec 8, 2007 | 06:06 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i think he means goin from 89 octane to higher </TD></TR></TABLE>
bingo, higher octane.
Old Dec 9, 2007 | 06:19 AM
maxpsi's Avatar
92-93 B8's = pair of valve reliefs
94-95 B8's = 4 valve reliefs cut.
Old Dec 9, 2007 | 08:02 AM
97grnrs's Avatar
Default Re: (maxpsi)
i did it using the block with only 2 valve reliefs per piston. it still cleared.
Old Dec 9, 2007 | 08:43 AM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">
94-95 B8's = 4 valve reliefs cut. </TD></TR></TABLE>
Wrong Chief
Here's a picture of my D15B8 block, you got it backwards.
The rumor was that honda used left over pistons from the D15B2 *I think thats what it was* for the earlier models of CX's untill they ran out.
Old Dec 9, 2007 | 12:17 PM
maxpsi's Avatar
92-93 B8's = 4 valve reliefs cut.
94-95 B8's = pair of valve reliefs</TD></TR></TABLE>
Like that?
Old Dec 9, 2007 | 01:25 PM
Dasfinc's Avatar
To my understanding
92- (to Some point in 93)B8's = 4 valve reliefs cut.
since I know mine was made mid-year 92, and some people with 93's do and some don't have the 4 valve reliefs.
once they ran out of the 4 valve pistons they started using just 2 valve pistons.
Also all models of 92 civic has wiring for Vtec and 4 wire O2's at the Shock-Tower to the ECU, unlike 93+ which you have to wire all the way to the ECU.
Old Dec 9, 2007 | 01:27 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i did it using the block with only 2 valve reliefs per piston. it still cleared. </TD></TR></TABLE>
I still wonder about that...
Was it a Vtec head?
Old Dec 9, 2007 | 02:16 PM
97grnrs's Avatar
yes. i know for a fact because it was my 2nd honda i ever had. 93 cx civic. 8V engine. block had only two indents per piston. i put a z6 head on it. no problems clearing, may have been real close but never hit.
