p30 vtec engagement?
Old Dec 6, 2007 | 03:35 AM
polishedturd's Avatar
I like PIE
Default p30 vtec engagement?
can anybody tell me when vtec is supposed to engage on a p30 ecu?
i have a virgin p30 ecu(i think) on my gsr and ive noticed vtec engagement is at 5400-5600rpm, is that right?
thanks in advance h-t
Modified by polishedturd at 4:45 AM 12/6/2007
Old Dec 6, 2007 | 04:37 AM
VRD^sam's Avatar
Default Re: p30 vtec engagement? (polishedturd)
thats about right, gsr's vtec engages at 4400...
Old Dec 6, 2007 | 04:49 AM
B16B_coupe's Avatar
HRD PKR
Default Re: p30 vtec engagement? (VRD^sam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^sam &raquo;</TD></TR><TR><TD CLASS="quote">thats about right, ...</TD></TR></TABLE>
Old Dec 6, 2007 | 08:48 AM
iH8RICERZ's Avatar
well, on the stock gsr ecu used with a gsr motor w/ the stock intake manifold...vtec x over is at 4400 rpm and the iabs open at around 5700 rpm. If you take a p30 ecu and run it on a stock gsr, I believe the IABS stay open and vtec is around 5700 rpm.
Old Dec 6, 2007 | 09:56 AM
I like PIE
Default Re: p30 vtec engagement? (iH8RICERZ)
[QUOTE=iH8RICERZ]well, on the stock gsr ecu used with a gsr motor w/ the stock intake manifold...vtec x over is at 4400 rpm and the iabs open at around 5700 rpm. If you take a p30 ecu and run it on a stock gsr, I believe the IABS stay open and vtec is around 5700 rpm.[/QUOTE]
are you sure about this?
has anyone heard of holding the iab diaphram valve ( its located outside the stock gsr manifold on the right side) open with a zip tie????? if so can you list any pros and cons of doing this, thanks.
Old Dec 6, 2007 | 10:06 AM
iH8RICERZ's Avatar
If you leave it open, you lose mid-range power and torque.....reasoning why honda designed that type of intake manifold for the gsr.
Old Dec 6, 2007 | 10:09 AM
St Jimmy's Avatar
* B A N N E D *
http://www.xenocron.com/install/OBD1-IABs.htm
Maybe that will help you understand it better so you stop posting about iab's and bumping the post up every half hour. Seriously do a google search, do your own research it really isnt that hard.
Old Dec 6, 2007 | 10:14 AM
I like PIE
Default Re: p30 vtec engagement? (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.xenocron.com/install/OBD1-IABs.htm
Maybe that will help you understand it better so you stop posting about iab's and bumping the post up every half hour. Seriously do a google search, do your own research it really isnt that hard.</TD></TR></TABLE>
im sorry i must have mistaken this for a forum that we ask questions and discuss them with other honda enthusiasts. my bad
Old Dec 6, 2007 | 10:24 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">
im sorry i must have mistaken this for a forum that we ask questions and discuss them with other honda enthusiasts. my bad</TD></TR></TABLE>
Thats exactly what it is. I assume your not a retard, and most people with a tad bit of intelligence would know to search first. Do you think your the only one that has questions about IAB's?
tealsvteceg
40
Aug 15, 2010 10:21 AM
VTECth1s
Aug 22, 2006 09:53 AM
jay_cue
Jan 5, 2006 11:33 PM
ksilaphet
Jul 24, 2003 01:37 PM
