Where to get 2.5" Bpipe?
typeone bpipe...see my sig
EDIT: My first reply was a bit unclear. Type One b pipe isn't 2.5".
[Modified by Reid, 11:12 AM 6/26/2002]
T.1.R Full stainless , top notch quality.
For more info please contact http://www.randdmotorsports.com
https://honda-tech.com/zerothread?id=214169
its 2.5in OD and 2 3/8in ID...its available now pre-made
anything else will have to be custom made...
[Modified by Reid, 2:56 PM 6/26/2002]
I think if you want a 2.5" b-pipe, you can only look for something made in USA.
Because I think in Japan, all the exhaust tubes are came in either 60, 70, or 80mm (may be some in 65mm too, but I never see any yet!!).
2.5"=63mm, so I doubt that anything made in Japan would have a 63mm OD. So you are lucky, since you are in the US, just goto a local muffler shop that can do mandrel bent and have them make one for you.
Dynamic Autosports has a made in Japan Greddy GSR exhaust for high horsepower Integras (70mm). I don't recommend this exhaust unless the car is going to make at least 200hp to the wheels. The exhuast is really loud, but it does come with a silencer.
949-457-1234 ask for the Power Extreme 2
for the price of the T1 b-pipe i would have to recomend it. i've looked at having a 2.5" b-pipe only made so that i could run the stock muff on the street and then spoon n1 at the track and i could have gotten the T1b-pipe/spoon muff together for a little more then just the custom 2.5" b-pipe.
Will the JDM ITR bpipe (is this 2.5" thru?) bolt right up to a USDM ITR muffler?
I know it will have to be shortened, unless there is an aftermarket 2.5" high-flow cat that will bolt up to the JDM bpipe and the JDM 4-1?
b00sted4dr
Dec 23, 2003 11:11 AM
pinota
Oct 28, 2002 11:00 AM
