anyone know the compression?
Old Dec 5, 2007 | 10:46 PM
v8hnta's Avatar
Default anyone know the compression?
hey guys just wanted to see if someone out there knew what my compression in my b18 (ls) needs to be at. if it makes any difference its a 90, and its in the REX
Old Dec 6, 2007 | 12:00 AM
lv6l's Avatar
There are serveral B18 motors.
Here are the spec for B18A1:
Compression 9.2:1
Compression test:
@ wide open throttle
Normal - 185
Minimum - 135
Max variation - 28
Modified by lv6l at 12:34 PM 12/6/2007
Old Dec 6, 2007 | 02:18 AM
TheCheeseWedge's Avatar
usually about 180psi across
must be within 10% on each, if out of 10% range do valve adjustment and recheck. the 10% is what matters not so much the peak psi
Old Dec 14, 2007 | 06:27 AM
v8hnta's Avatar
Default Re: (TheCheeseWedge)
thanks a lot guys i appreciate the help, anyone selling a t3 t4 turbo? ( in good condition)
Old Dec 14, 2007 | 07:35 AM
crxfreak1117's Avatar
Default Re: (v8hnta)
check here http://www.hondamarketplace.com/
jeffcat
Dec 16, 2013 07:41 AM
vinceiscoo
Jan 8, 2010 09:53 PM
puma2132
Feb 8, 2009 02:37 PM
Nisif
Apr 12, 2005 09:13 AM
