I want to sand my car down and get it reday for primer.
Old Dec 5, 2007 | 05:53 PM
IROCKCIVICS's Avatar
Default I want to sand my car down and get it reday for primer.
I want to sand my car down and get it ready to prime it myself but the problem is I have no clue on how to do this or what to use basically nothing.... I need some pointers on how to sand then paint off my car and them get it prime.... Can someone help me please, thanks.
Old Dec 5, 2007 | 06:19 PM
fastedie's Avatar
Default Re: I want to sand my car down and get it reday for primer. (IROCKCIVICS)
Ok Usually a scuff with 320 grit and a block will do it but if you have clear flaking off the car then you need to take down abit farther at least into the good paint. Youll know your there when the dust from sanding starts to turn to your paint color from white.... (unless your car is white ) Any how go to walmart and get you a sanding block and some 150 grit 220 grit 320 grit and 400grit make sure you get the wet sand paper (used with water to help lube) that should be good enough.... Are you fixing any bodywork or just primering it? You Sprayin yourself?
Old Dec 8, 2007 | 11:01 AM
Nah I'm not doing anybody work just sanding it down... My car is clover green pearl if that helps.
Nooch
Paint and Body
Oct 14, 2011 11:47 AM
r33dm0n3y
Paint and Body
14
Jun 15, 2009 04:53 AM
Armorzaku
Paint and Body
Mar 18, 2009 08:14 PM
stemiched
Mar 28, 2007 10:10 AM
