Hissing from MAP sensor, vacuum leak? (B16A2)
Old Dec 5, 2007 | 05:40 PM
Hardedge's Avatar
Default Hissing from MAP sensor, vacuum leak? (B16A2)
I just threw my head back on with new gaskets and it runs with no CELs, but it would shoot to 2000 RPM right on startup and there was a hissing noise from around the throttle/manifold. I moved the intake and snugged down the throttle body bolts really good and was relieved to have a more calm 1450 RPM on startup. However, the hiss is still there! I felt around and it's right on the MAP sensor/TB mating surfaces. Also, the idle seems to drop when I wrap my hand over it the right way (though I don't know to what as I'm working alone). Here's the kicker; the MAP sensor was never previously removed from the throttle body and it also won't snug down any more without stripping the screw heads. Anybody know where I should start?
go'in crazy
Aug 27, 2009 12:42 PM
Hondamonster
Jun 18, 2007 05:49 PM
PearlBlueType-S
Jan 7, 2006 09:27 AM
comptechgsr2000
May 8, 2002 03:53 PM
