What Hondata program is right for me?
Old Dec 5, 2007 | 05:33 PM
xialbyix's Avatar
Default What Hondata program is right for me?
OK... well I currently have a 00 GS-R, which will be fitted with JDM ITR pistons, skunk2 stage 1 cams, complete S2 valvetrain (Flat faced valves), light port and polish, 2.5 exhaust, a rage tri-y header.and possibly a shaved head gasket. Well i was wondering what Hondata system would work best for me. I am trying to achieve around 200 whp.
I have searched, but did not find a definite answer... thank you.
Old Dec 5, 2007 | 06:21 PM
ls19integra95's Avatar
Default Re: What Hondata program is right for me? (xialbyix)
s200 would be fine... thats what i would do since your not turbo...
Old Dec 5, 2007 | 06:22 PM
db1_jdm's Avatar
i wish i had the money to build something similar you're building
Old Dec 5, 2007 | 06:49 PM
xialbyix's Avatar
Default Re: What Hondata program is right for me? (db1_jdm)
Yea, well I have saving for a while. I am pretty excited to get it finished.
Old Dec 5, 2007 | 06:50 PM
xialbyix's Avatar
Do you think that with a good tune it'll be possible to see anything over 205?
Old Dec 5, 2007 | 09:07 PM
those parts with the hondata ecu and some one to do a real good tune shouldnt be to hard to hit 200hp... a gsr is 170hp stock if im not mistaken... but since your building the entire head you may want to also get like an intake manifold, throttlebody, and intake... possibly also a fuel rail and maybe even fuel pressure regulator before the tune... with those also along with other parts you mentioned you should have no problem at all hittin over your 205hp goal with a real good tune...
Old Dec 5, 2007 | 09:12 PM
posHonda's Avatar
Default Re: What Hondata program is right for me? (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">those parts with the hondata ecu and some one to do a real good tune shouldnt be to hard to hit 200hp... a gsr is 170hp stock if im not mistaken... but since your building the entire head you may want to also get like an intake manifold, throttlebody, and intake... possibly also a fuel rail and maybe even fuel pressure regulator before the tune... with those also along with other parts you mentioned you should have no problem at all hittin over your 205hp goal with a real good tune...</TD></TR></TABLE>
200hp and 200whp are two very different things.
OP, also grab an intake manifold and an AEM ITR CAI while youre at it. Im thinking you should be around the 200whp mark. If you got more aggressive cams than definitely. Are you taking layers out of the OEM headgasket are getting another one?
Old Dec 5, 2007 | 09:27 PM
Default Re: What Hondata program is right for me? (posHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by posHonda &raquo;</TD></TR><TR><TD CLASS="quote">
OP, also grab an intake manifold and an AEM ITR CAI while youre at it. Im thinking you should be around the 200whp mark. If you got more aggressive cams than definitely. Are you taking layers out of the OEM headgasket are getting another one?</TD></TR></TABLE>
as he said id pick up the mani, and intake but also maybe even a throttle body a lil bigger then your stock and you should have no prob. hittin your 205whp with a real good tune...
Old Dec 5, 2007 | 10:22 PM
mtber's Avatar
Depends on what options you want.
s100/s200/s300 all have different options & capabilities.
Old Dec 5, 2007 | 10:52 PM
1tuffbb6's Avatar
Default Re: What Hondata program is right for me? (mtber)
IMO the s100 is still a great program but somewhat outdated, and the s300 is somewhat designed around boost.
s200
Hondata.com, check out all the different options for yourself.
Old Dec 6, 2007 | 05:29 AM
xialbyix's Avatar
I was probably going to buy a new one as compared to shaving layers off the oem, only b.c I am not certain how simple that is.
Old Dec 6, 2007 | 05:32 AM
xialbyix's Avatar
That was my other question... if I bought a Skunk2 IM or even an ITR manifold, will I need to replace my CAI? I forgot to mention that there is an AEM CAI on the car already. Is it true that I will lose torgue with a larger TB and new IM?
Old Dec 6, 2007 | 07:08 AM
OH_1fstgsr's Avatar
I don't think you mean program, you mean system, right?
First off you will need a OBD1 ECU for any of the three Hondata options with a OBD2&gt;OBD1 cable.
Yes you will need to replace the CAI with one for a ITR. Throttle body location is different between a GSR and ITR.
Yes you will lose mid range power with a single runner manifold. If your tuner is really really good you may get most of it back to before you changed it and only gain very little top end.
Some other things you may need:
larger injectors 310cc or 370cc, depends on your final HP goal
high flow cat 2.5"
bore out your TB or get larger one
I have a similar set up USDM Pistons, ITR Cams, PnP head, I am running the S300. Very nice good system and I was able to get my car running without my tuners help nice plus. I am also running the GSR intake ported and right now I should be at about 190whp. Haven't got to the dyno yet, only street tuned.
Old Dec 6, 2007 | 07:11 AM
xialbyix's Avatar
Default Re: What Hondata program is right for me? (OH_1fstgsr)
Thanks for the advice... I was very well aware of the OBD conversion. MY final HP goal will most likely not exceed 210. Does this warrant larger injectors?
Old Dec 6, 2007 | 07:27 AM
OH_1fstgsr's Avatar
You will need larger than the 240cc for anything higher than 175whp.
This does depend on your fuel pressure and what duty cycle you are willing to live with. You should try to stay below 80% if possible.
Right now on 370cc injectors I am at 62% with stock fuel pressure at my estimated 190whp.
Old Dec 6, 2007 | 06:19 PM
xialbyix's Avatar
Arent stock prelude injectors 310cc? Would that be suitable?
datsun71
Engine Management and Tuning
Jul 26, 2011 12:20 PM
jmoss1987
Jul 17, 2006 10:34 PM
baonest
Aug 10, 2002 02:51 PM
Evil_Wizard
22
Apr 11, 2002 06:17 PM
