what to do about rust on new engine parts
Old Jun 26, 2002 | 11:13 AM
88CRXHybrid's Avatar
Default what to do about rust on new engine parts
Well being my curious self I like to touch and examine every new piece of the engine that I am building. My guess is that the oil from my fingers promoted the rust to form on my Prodrive oil gear, one of the eagle rods I have opened, and the DD clutch plate. Is there any consern I should have for this slight surface rust or how would be the best way to clean it off(wire brush?) or do I need to clean it off at all?
Old Jun 26, 2002 | 11:28 AM
BROOD's Avatar
Default Re: what to do about rust on new engine parts (88CRXHybrid)
Probaby nothing more than minor surface rust. Try alittle WD40 and a clean cloth it will probably rub off. That is why I spray everything down with WD40, I buy it by the case. YOu could also try some fine steel wood with light pressure if it is still there.
On the pressure plate you should follow it up with some brake cleaner before installing.
[Modified by SLPR, 12:51 PM 6/26/2002]
Old Jun 26, 2002 | 11:37 AM
Default Re: what to do about rust on new engine parts (SLPR)
I actually already did this but it didnt all come off
Old Jun 26, 2002 | 12:35 PM
Steve91's Avatar
You could go to the hardware store and buy a product called Naval Jelly. It removes rust like majic. I always keep parts like rods, etc. coated with WD40 or oil in a ziplock bag. I wouldn't worry too much about it, just put them in bags with oil.
Vtec04
Detailing
Oct 26, 2017 09:48 PM
rhdekhatchie
Nov 25, 2008 05:37 PM
Oregon
25
Oct 18, 2006 10:51 AM
Takumi Fujiwara
May 4, 2005 01:29 AM
ITR#00-1077
Jul 26, 2002 10:46 AM
