How long does it take to install reverse indiglo gauges????
Old Jun 26, 2002 | 10:52 AM
loki2323's Avatar
Default How long does it take to install reverse indiglo gauges????
anyone thats done this before know about how long I should expect it to take me??
Old Jun 26, 2002 | 11:06 AM
dingusjt's Avatar
Default Re: How long does it take to install reverse indiglo gauges???? (loki2323)
Well, you take off the moulding around gauge cluster, remove the mounting screws on the metal brackets, remove the screws under the caps on top of the dash by the window (atleast its that way on an 89), then slide it out, disconnect the wires and then its out for you to tinker...
i'm guessing you have the kind that are supposed to slide onto your gauges with out needle removal....i would say anywhere from 20-50 depending on what goes wrong...things always go wrong. I planned on swapping out my engine in 3 days and well so far its taken me almost a week.
Old Jun 26, 2002 | 11:16 AM
sigmachibri's Avatar
I installed them on a 91 honda accord...it didnt take that long cause i had the service manual. The gauge cluster housing is connected to the center area where the heating controls are. other cars arent like this so i was lucky i had the book to tell me where all the screws were. Some were hiden behind vents and some were hiden behind the hazard buttons. Would have been pretty tricky without the service manual. Hooking up the power for the gauges wasnt a big deal as long as you know how to run the relay. Once you get the dash off it is very simple to attach the new gauges. I would say plan on spending 2 to 3 hours doing this project. Overall it is relatively simple
Old Jun 26, 2002 | 11:30 AM
BROOD's Avatar
The "reverse" time to install indiglow gauge faces??
Seriously, I installed a set of indiglows in a friends ride, it was an under 1 hour and two beer job. No problem
Old Jun 26, 2002 | 11:40 AM
loki2323's Avatar
Default Re: How long does it take to install reverse indiglo gauges???? (SLPR)
yeah I was looking at it and I really dont understand how people have been telling me it takes 3 hrs.....I think it could be done in a little over an hour
Old Jun 26, 2002 | 12:53 PM
depending how fast you can get the dash off, that is the time consuming activitity. everything else is slipping on. the wiring up is the only other question. but whenever i or anyone else says an hour there is always a complication. so at best, 1 hour at worst 2-3 hours. very simple though
Old Jun 26, 2002 | 02:44 PM
loki2323's Avatar
Default Re: How long does it take to install reverse indiglo gauges???? (sigmachibri)
On a 98 honda civic how many backlight bulbs are there that I would be removing??
The install took me about 45 mins....just not sure which bulbs to take out and which to leave in from the original backlights...............
Old Jun 27, 2002 | 08:30 AM
loki2323's Avatar
also...as far as the install...I was very carefull with my needles....why does everyone bug about breaking them? I mean how hard is it to actually throw the needles out of whack so they read wrong?
Old Jul 6, 2002 | 07:32 PM
MikeMAN's Avatar
i would say 25-30 mins maybe 1hr at the most....why does it take everyone so long? im not THAT competent..lol
if anyone needs some...i got some that i wanna get rid of ! :D
firetyphoon1
Honda Civic (2001 - 2005)
Sep 7, 2007 09:27 PM
vtecpower3088
Dec 31, 2005 05:15 PM
aznvi3tkidz
Sep 7, 2005 02:32 PM
streetmodified
41
Apr 8, 2005 10:16 AM
ridiculous
Jun 6, 2002 07:08 AM
