temp needles shoots up to HIGH on startup
Old Dec 5, 2007 | 03:42 AM
devilpuppy's Avatar
Default temp needles shoots up to HIGH on startup
I just purchased a 1990 Accord EXR....
the heat works perfect, but when I start the car..when its dead cold....or even if I Just turned it off and came back after 30 mins...
the temp needs jumps to high....then drops back to cold....then slowly moves up as it reaches proper temp...
i kno if the thermostat was stuck open...i woudlnt have any heat...but i do have heat...does that mean the thermostat is stuck closed? or is it just another problem all together?
Old Dec 6, 2007 | 12:07 PM
devilpuppy's Avatar
ttt
Old Dec 6, 2007 | 12:16 PM
awdgsx96's Avatar
Default Re: (devilpuppy)
May just be the circuitry on the back of the gauge. My speedo was working improperly, due to the said circuitry. It's an easy fix.
I have a 94, I don't know if it was as much as problem for your generation though.
djfob
Feb 16, 2018 05:27 PM
Spoolind16
Jun 17, 2007 10:15 PM
electric-boost
Dec 11, 2006 08:37 PM
typeRobtypeS
Nov 20, 2005 08:02 PM
ButterMule
Nov 27, 2004 10:19 AM
