GT3076R Max boost?
Old Dec 5, 2007 | 01:34 AM
140sx's Avatar
Default GT3076R Max boost?
Hi iam almost done with my s2000 build and Im a little curious how many pounds i can pull out of my gt30.
Thanks,
Zach
Old Dec 5, 2007 | 06:50 AM
TheShodan's Avatar
Moderator
Default Re: GT3076R Max boost? (140sx)
Check the compressor maps that are available. The power output can vary. It's not just about boost pressure
Old Dec 5, 2007 | 10:42 AM
sp00led's Avatar
Default Re: GT3076R Max boost? (TheShodan)
On my 84mm gsr I was getting around 28-29psi spikes but it will hold 23psi pretty solid. HP/TQ is in the sig.
Trackmasters has a s2000 in the shop right now with a 3076r on it. PWR water/air setup which turned out to fit pretty good. The motor isn't built so we probably won't go over 400whp but i'm pretty sure he should be able to make that around 16psi.
Old Dec 5, 2007 | 10:26 PM
140sx's Avatar
Default Re: GT3076R Max boost? (sp00led)
inlinepro's turbo kits use a 3076r and they all make in the mid 400s on just a head gasket that bumps the compression down to 9.1. im running a 10.1 piston in mine though, idk how big of a differance it will make pwr wise.
Old Dec 5, 2007 | 10:33 PM
purpleh22's Avatar
I'm using a GT 3076 and changed to a .82 AR. On my H22 (10:1 Arias) it makes 440 - 465 whp @ 18 psi.
Old Dec 6, 2007 | 06:24 AM
TheShodan's Avatar
Moderator
Default Re: GT3076R Max boost? (purpleh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 &raquo;</TD></TR><TR><TD CLASS="quote">I'm using a GT 3076 and changed to a .82 AR. On my H22 (10:1 Arias) it makes 440 - 465 whp @ 18 psi.</TD></TR></TABLE>
That's about right, and is easily obtainable in a .63A/R. turbine housing size changes back pressure and shifts the output curve slightly. Until you get to the larger framed turbos, the housing size b/w .63 and .82, to me isn't all that much.
Old Dec 7, 2007 | 04:15 PM
ludeDVR's Avatar
I also have the .82 on my h22 with 9:1 CP's making 422 at 19psi dropping to 17 at redline
ass_turtle
Honda S2000
Jun 9, 2016 07:04 PM
tommikaira
Honda S2000
Jan 22, 2009 09:33 AM
EJ8 GSR-T
Honda S2000
Jul 2, 2006 01:17 PM
airwalk07143
Mar 22, 2006 05:53 AM
wannas2k
Honda S2000
Jan 3, 2005 08:07 AM
