Coolant leak near headgasket with pix help plz
Old Dec 4, 2007 | 10:12 PM
HELLAnorcal's Avatar
Default Coolant leak near headgasket with pix help plz
My question is where is it leaking from ? and how can i fix it. Thx !
Old Dec 5, 2007 | 12:13 AM
Eran's Avatar
HT White Ops
Looks like you're leaking from the outlet coolant neck.
You could try cleaning the coolant neck and the mounting surface really well, get all the oils off and whatnot. Then scuff it with a scotchbrite bad and apply some liquid gasket.
Old Dec 5, 2007 | 03:33 AM
ej1-usdm's Avatar
what he said, clean it out really good, an used some black silicon =] it works wid almost everything
Old Dec 5, 2007 | 04:27 AM
tpr's Avatar
tpr
Default Re: Coolant leak near headgasket with pix help plz (HELLAnorcal)
Take off the water outlet, clean both surfaces throughly, if they are pitted buy the paper gasket use black or grey RTV. Also please check for cracks in the outlet housing casting. If it is cracked hit the junk yard for a replacement.
Old Dec 5, 2007 | 04:37 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I too was going to suggest resealing the waterneck.
Very rarely, if ever, will a head gasket leak coolant externally. They usually leak coolant into the cylinders, which causes white smoke.
I'd suggest getting Honda Bond from your local Honda dealership to use as the surface sealer/gasket maker for the junction of the neck and cylinder head. Honda bond is the best substance for the job, and it's also what the Honda factory seals that exact area with when the engine is assembled.
kte324
Oct 26, 2009 04:37 PM
A-dub5513
May 18, 2009 04:08 AM
CleanHatch
Nov 5, 2005 12:19 AM
specialedition
Jan 11, 2005 05:32 PM
Tad
Jul 6, 2004 09:50 PM
