TIRE question 205/60/15
Old Dec 4, 2007 | 07:52 PM
roddy9's Avatar
Default TIRE question 205/60/15
This might be a stupid question and I might get Bashed but would 205/60/15 fit on my 92 civic hatch thats lowered? cause currently I have 195/65/15 and they slightly rub when i turn. So If anyone with this knowledge know please inform me. Thanks
Old Dec 4, 2007 | 08:02 PM
devney's Avatar
why such large tires?
Old Dec 4, 2007 | 08:07 PM
nicko360's Avatar
* B A N N E D *
Default Re: TIRE question 205/60/15 (roddy9)
depends on how much your car is lowered, but they will most likely fit
Old Dec 4, 2007 | 08:15 PM
Panda Eg6's Avatar
Default Re: TIRE question 205/60/15 (nicko360)
LOL on ur sig devney brings back some old movie memories hehe
Old Dec 4, 2007 | 08:26 PM
devney's Avatar
Default Re: TIRE question 205/60/15 (Panda Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">LOL on ur sig devney brings back some old movie memories hehe</TD></TR></TABLE>
lol yep
Old Dec 4, 2007 | 08:37 PM
roddy9's Avatar
I need mad traction and just upgraded to Tokico with ground control...but not much help...TRACTION BAR will be soon...but since my friend has some 205/60/15 will this be good..your thoughts are greatly appreciated THANKS!!
Old Dec 4, 2007 | 08:40 PM
Panda Eg6's Avatar
Default Re: (roddy9)
yea it would help but look kinda wierd lol!
Old Dec 4, 2007 | 08:41 PM
93egSLEEPER's Avatar
you should be running 205/50/15 if you want the same stock overall circumfrence and diameter so ur speedo isnt off
Old Dec 4, 2007 | 08:45 PM
roddy9's Avatar
haha I dont give a damn if it looks weird as long as it fits,clears and grabs...i got dip off the line by a R32 cause of no traction..so i need to get revenged...
Old Dec 4, 2007 | 08:48 PM
get some slicks
Old Dec 4, 2007 | 09:00 PM
95ProjectEJ1's Avatar
Default Re:
Like the others have said... get yourself some 205/50/15's or 195's
Old Dec 4, 2007 | 09:09 PM
Hardedge's Avatar
He'll be lucky if he doesn't blow the welds on the intake!
For the love of God, my EM1 has 60s on it (instead of the factory 55) and they look beefy on the car. I can't imagine how bad a 60 would look on a '92 hatchback. And that model is supposed to be a 50, right? That's almost an inch more in overall diameter. Also, your speedometer reading is going to be inaccurate.
Old Dec 4, 2007 | 09:12 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roddy9 &raquo;</TD></TR><TR><TD CLASS="quote">but since my friend has some 205/60/15 will this be good..your thoughts are greatly appreciated THANKS!!</TD></TR></TABLE>
No, it will not be good. It will be 2" too large in diameter, throwing off your speedometer, odometer, and effective gearing by 9%. You'll also likely run into clearance issues, and you won't be gaining any traction by switching to them.
The correct size for your car would be 195/50-15. Focus on selecting a high-performance tire in that size, rather than installing random tires that are incorrectly sized.
Old Dec 4, 2007 | 09:49 PM
Hardedge's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
The correct size for your car would be 195/50-15. Focus on selecting a high-performance tire in that size, rather than installing random tires that are incorrectly sized. </TD></TR></TABLE>
And the addition of significant rotating mass doesn't help either.
Just curious, how did you conclude 2 inches? Correct me if I'm wrong, 60 mm is 10 mm greater than 50 mm, times the height of 2 sidewalls would be a 20 mm increase, out of 1 inch (25.4 mm), would be roughly 4/5", not 2".
Old Dec 4, 2007 | 10:04 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Hardedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardedge &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, how did you conclude 2 inches? Correct me if I'm wrong, 60 mm is 10 mm greater than 50 mm, times the height of 2 sidewalls would be a 20 mm increase, out of 1 inch (25.4 mm), would be roughly 4/5", not 2".</TD></TR></TABLE>
The appropriate 15" tire size for a '92 Civic hatchback would be 195/50-15.
195mm width x 50% aspect ratio = 97.5mm sidewall height. Multiply that times two, convert to inches, and add the 15" wheel size, and you arrive at 22.68" total diameter.
205mm width x 60% aspect ratio = 123mm sidewall height. Multiply that times two, convert to inches, and add the 15" wheel size, and you arrive at 24.68" total diameter.
The overall difference in diameter between the two is 2 inches.
Here's a pretty useful online tire size calculator: http://www.miata.net/garage/tirecalc.html
Old Dec 4, 2007 | 10:09 PM
Hardedge's Avatar
D'oh! Sorry, I was thinking the number was sidewall width. I forgot about aspect ratio. Guess I need to go back to tire school.
Me...
Old Dec 4, 2007 | 10:14 PM
Eran's Avatar
HT White Ops
Actually, the proper size for a 15" wheel on a 92-95 Civic is a 195/55/50 or a 205/50/15.
The stock size is 185/65/14. A 195/50/15 would be over a 3% discrepancy in diameter.
Old Dec 4, 2007 | 10:23 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Actually, the proper size for a 15" wheel on a 92-95 Civic is a 195/55/50 or a 205/50/15.
The stock size is 185/65/14. A 195/50/15 would be over a 3% discrepancy in diameter.</TD></TR></TABLE>
Tire Rack lists the stock size for a 1992 Civic Si hatchback as 185/60-14, and the 1992 Civic DX hatchback as 175/70-13, making the proper 15" tire size 195/50-15.
The Civic hatchback did not move to the larger size until the 6th generation.
Old Dec 4, 2007 | 10:29 PM
roddy9's Avatar
sounds good I appreciate everyones thoughts and knowledge...THANKS! looks like 195 would be a good route..
Old Dec 4, 2007 | 10:30 PM
Eran's Avatar
HT White Ops
The Civic hatchback did not move to the larger size until the 6th generation. </TD></TR></TABLE>
The site I'm using must have suspect information then. I was using the stock sizing included in the tire calculator.
Old Dec 4, 2007 | 10:34 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">The site I'm using must have suspect information then. I was using the stock sizing included in the tire calculator.</TD></TR></TABLE>
What site are you referencing?
Tire Rack and Discount Tire both seem to indicate that the larger sizing didn't appear until the 6th generation, though they differ slightly as to what point in the generation it was instituted.
Old Dec 4, 2007 | 10:36 PM
Eran's Avatar
HT White Ops
Tire Rack and Discount Tire both seem to indicate that the larger sizing didn't appear until the 6th generation, though they differ slightly as to what point in the generation it was instituted. </TD></TR></TABLE>
I was using 1010Tire, a Canadian company similar to Tire Rack or Discount. I use that calculator instead of the Miata one because it allows for multiple tire comparisons.
Old Dec 5, 2007 | 01:01 AM
d1sturb3d's Avatar
your tire setup is big..but base on the post of the others you get the picture..
195/55/15 is your best bet.. =D
sony224422
Aug 26, 2007 05:56 AM
STN_Pat
Sep 24, 2005 09:30 PM
litterbox
Mar 10, 2005 12:37 PM
NickEG
Apr 25, 2004 09:41 AM
soloIntegra
Aug 24, 2003 05:31 PM
