Intake Manifold question
Old Dec 4, 2007 | 07:41 PM
ex_ricer's Avatar
Default Intake Manifold question
Hi.
I own a 1996 Honda civic DX
motor does not have an intake manifold.
planning on getting one, say i get one off an EX model same gen, would it bolt up?
Old Dec 4, 2007 | 07:46 PM
ekquebec's Avatar
Default Re: Intake Manifold question (ex_ricer)
It fit bolt-on but you must save your throttle body because you have a rotatif IAC and the Ex have a linear IAC.
Old Dec 4, 2007 | 08:09 PM
nicko360's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex_ricer &raquo;</TD></TR><TR><TD CLASS="quote">Hi.
planning on getting one, say i get one off an EX model same gen, would it bolt up?</TD></TR></TABLE>
what do you mean your car doesnt have an intake manifold, do you drive it?
Old Dec 5, 2007 | 05:22 AM
ex_ricer's Avatar
Default Re: Intake Manifold question (nicko360)
DX model doesnt come with an intake manifold, just throttlebody.
Old Dec 5, 2007 | 06:40 AM
hondamark35's Avatar
careful... think about things before you post them.
unless you have a single cylinder engine you have a manifold.
what you mean to say is that you have a downdraft TB and you want the more typical sidedraft arrangement.
like you read, you can use the EX manifold, it'll bolt up to your head and DX TB. you're going to need to make the bypass coolant hoses work. I suggest getting hose by the foot from an autoparts store for the small diameter stuff. you can keep your fuel rail and injectors, all of your sensors, and even your throttle cable. the cable however, will need to be held out of the way. I reused some of the mount clips for it and bent them to hold the cable above the strut area.
you must used the DX TB gasket. this is important. the EX gasket will create a huge vacuum leak and an annoying idle problem.
have fun. it helps this motor a lot. i've actually gotten better gas mileage after the switch.
Old Dec 5, 2007 | 07:35 AM
JDM_Frijoles's Avatar
Default Re: Intake Manifold question (hondamark35)
He has this^^^ and I think he wants VVV....
Old Dec 5, 2007 | 11:44 AM
ITR_Sol's Avatar
Default Re: Intake Manifold question (JDM_Frijoles)
yes sir, deff a hp killer. But, to asnswer you question, Any dseries intake will bolt up to your motor. Im sure this is already in archieves but, ntl, just make sure to save all your sensors and swap the out like the guy sd above about the iac. Check out the archieves to see if anyone has got these pics and process on a write up before. Im sure its there. seen it b4.
98HondaCivicDX
Sep 15, 2004 05:06 AM
allablur
Aug 19, 2004 07:34 AM
AFTERZERO
Jul 14, 2004 12:02 AM
mrsurfermike2001
Feb 26, 2003 09:52 AM
2k2civic
Mar 4, 2002 06:49 AM
