stuck parking brake (e-brake) cable
Old Dec 4, 2007 | 04:54 PM
thebinaryman's Avatar
Default stuck parking brake (e-brake) cable
because i have a 5spd i nearly always use the brake to park the car. recently it's been cold here in wisconsin and on occasional nights the e-brake cable is sticking, the handle will go down, but the wheels are dragging. i took the plastic center panel off:
i should see this:
instead, i see this
if you can't read my ascii art, the passenger side break cable is sticking, and the thingy that connects the cables to the handle is tilted because of the stuck cable. i cannot even force it in with a pliers, i believe it's frozen.
how can i lubricate this or unstick this cable? it probably will unstick itself eventually, but is there a way i can free it now, and in the future just not use the brake when i'ts cold? thanks.
Old Dec 4, 2007 | 05:12 PM
93egSLEEPER's Avatar
Default Re: stuck parking brake (e-brake) cable (thebinaryman)
hot water to get it thawed out is what it sounds like u need. then wd 40 it... then never set it again. i just leave mine in gear.
Old Dec 4, 2007 | 05:16 PM
good idea. where should i apply the hot water and wd-40 though?
Old Dec 4, 2007 | 05:19 PM
Default Re: (thebinaryman)
up next to the handle where it attaches and in the rear where it is stuck... all onder the car of course. you should be able to tell where it is stuck when u get under there.
Old Dec 4, 2007 | 05:21 PM
ok thanks! it's dark and cold outside now, i'll take a look tomorrow morning. i love the fast replies from honda-tech. thanks again!
Old Dec 4, 2007 | 05:23 PM
no prob
flyinfree
Sep 9, 2011 08:55 AM
imadigitalgod
Jan 5, 2010 01:23 PM
ONEhaque
Nov 10, 2008 06:23 PM
HondaHeddie
Nov 11, 2006 04:20 PM
MechEng
Dec 7, 2003 09:13 AM
