How to tell if CABLE or HYDRO tranny.
Old Dec 4, 2007 | 04:39 PM
Nameless Warrior's Avatar
Default How to tell if CABLE or HYDRO tranny.
How can you tell on a 99 GSR? The shifting seem a bit harder than my Si which was a Hydro Tranny.
Another questions. Will it matter if I install a Hydro clutch/pressure plate onto a cable tranny?
THANKS!
Old Dec 4, 2007 | 04:44 PM
weavertime1's Avatar
Default Re: How to tell if CABLE or HYDRO tranny. (Nameless Warrior)
'94 and up integra are all hydro, unless someone installed a hyrdo to cable conversion, which is slim to none. Also, because your car is most likely hydro, you will need the hydro clutch.
Old Dec 4, 2007 | 05:26 PM
dwamp2006's Avatar
deff a hydro, nooo doubt about it
Old Dec 5, 2007 | 09:22 AM
Ls92's Avatar
I believe the pressure plate's are the same for the B series but the clutch discs are transmission specific (hydro/cable and the year also)
Old Dec 5, 2007 | 09:25 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (dwamp2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwamp2006 &raquo;</TD></TR><TR><TD CLASS="quote">deff a hydro, nooo doubt about it</TD></TR></TABLE>
Old Dec 5, 2007 | 10:50 AM
dickdragon's Avatar
Default Re: How to tell if CABLE or HYDRO tranny. (weavertime1)
x2
Old Dec 5, 2007 | 11:02 AM
all-mtr-teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">How can you tell on a 99 GSR? The shifting seem a bit harder than my Si which was a Hydro Tranny.
THANKS!</TD></TR></TABLE>
If its stock, its hydro, or to verify look to see if you got a clutch cable or a hydrolic line running to you tranny
Old Dec 5, 2007 | 11:18 AM
Default Re: How to tell if CABLE or HYDRO tranny. (all-mtr-teg)
I know it is 99.9 % hydro guys, but I have seen people swap cable trannies into newer tegs and civics, so I didn't want to rule that out. I would be willing to bet lots of money it is hydro though!!!
Old Dec 5, 2007 | 11:28 AM
What do you mean by it seems harder to shift, the pedal is harder to press down, or getting the shifter into gear is harder?
luvs2spooge
Aug 31, 2007 06:34 AM
flipldls
Jun 24, 2007 08:34 PM
ldanphanl
Mar 6, 2005 08:50 PM
frknlo87
Jul 13, 2004 12:28 AM
robbin
Apr 14, 2004 12:42 PM
