d16y8 injectors the same as b18a??? already searched
Old Dec 4, 2007 | 04:33 PM
98exturd's Avatar
Default d16y8 injectors the same as b18a??? already searched
i want to put b18 injectors for a lil more fuel but if there the same there really no point.... and what is the diff in injectors with a yellow bottom and a red bottom?
Old Dec 4, 2007 | 04:34 PM
ke98248's Avatar
Default Re: d16y8 injectors the same as b18a??? already searched (98exturd)
There's no point to doing that, buddy, if your motor is stock.
Old Dec 4, 2007 | 04:43 PM
andoxviii's Avatar
Default Re: d16y8 injectors the same as b18a??? already searched (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">There's no point to doing that, buddy, if your motor is stock.</TD></TR></TABLE>
he never said anything about his engine configuration, how do u know its stock? he asked a simple question about fuel injectors
Old Dec 4, 2007 | 04:45 PM
98exturd's Avatar
Default Re: d16y8 injectors the same as b18a??? already searched (andoxviii)
all i want to know is if they are bigger or if anyone knows the cc size of each, and if they will plug up and work and give me more fuel
Old Dec 4, 2007 | 04:47 PM
98exturd's Avatar
and does it matter that they come from a dohc and go in a sohc
Old Dec 4, 2007 | 05:09 PM
98exturd's Avatar
bump
Old Dec 5, 2007 | 04:14 PM
ke98248's Avatar
He never said it was modified either.. I think the stock d16y8 injectors are 245cc, not sure about the b18a
Old Dec 5, 2007 | 05:25 PM
blk92_d16's Avatar
Been a while since I've seen the specs on the B-series stuff...but the Y8 is 240ish. Some say 240, some say 245. I don't see why the B18 would be any larger?
Old Dec 5, 2007 | 05:34 PM
ltrkstr2k's Avatar
Default Re: (blk92_d16)
yeah d and b series injectors are the same size. both are 240cc and as long as you have the same obd they are interchangeable.
Mr. Bojangles
Jul 2, 2013 04:52 PM
91tegboi
Mar 18, 2012 02:19 AM
...civic...
10
Mar 12, 2006 01:39 PM
Civiclx
Apr 7, 2004 01:22 PM
Wes d
Mar 6, 2002 07:38 PM
