side markers
Old Dec 4, 2007 | 02:29 PM
drg1989's Avatar
Default side markers
how do i wire the sidemarkers into the turn signals? is there a link that takes it step by step?
Old Dec 4, 2007 | 02:43 PM
Padawan's Avatar
Darth ModerVader
Default Re: side markers (drg1989)
It's not really a step by step sort of thing. You just locate the turn signal wires, and splice in to them.
Old Dec 4, 2007 | 02:46 PM
drg1989's Avatar
Default Re: side markers (Padawan)
ok. but the guy who installed them wired them to the running lights and they are always on. do i have to do anything special to separate them.
Old Dec 4, 2007 | 02:53 PM
Padawan's Avatar
Darth ModerVader
Do they also blink?
If so, you just need to disconnect the wire from the parking lights and connect it to a ground instead.
Old Dec 4, 2007 | 02:55 PM
drg1989's Avatar
nope just stay on. but i mean when i disconnect it from the red and black do i have to do anything else to those two wires?
Old Dec 4, 2007 | 03:07 PM
PinoyDelSol's Avatar
* B A N N E D *
You can buy Quick Connectors at walmart for like 4 bucks.. I think its better than splicing you wires.. Its basically a plastic piece that has metal in it.. You put the wires under the metal piece and clamp down on it with needle noise pliers. Here is what is sort of looks like. http://www.electriciansupplies...s.jpg
Old Dec 4, 2007 | 03:32 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">You can buy Quick Connectors at walmart for like 4 bucks.. I think its better than splicing you wires.. Its basically a plastic piece that has metal in it.. You put the wires under the metal piece and clamp down on it with needle noise pliers. Here is what is sort of looks like. http://www.electriciansupplies...s.jpg</TD></TR></TABLE>
Those are good, so are butt connectors:
Just pop both wires in and crimp down, it ownz splicing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drg1989 &raquo;</TD></TR><TR><TD CLASS="quote">nope just stay on. but i mean when i disconnect it from the red and black do i have to do anything else to those two wires?</TD></TR></TABLE>
There should be three wires coming out of your corner lights. One's a ground, one's a solid state (parking lights) circuit, and the other is a circuit with a relay in it (the turn signal).
If you get a multi-meter and turn your hazzards on, two of those (ground and turn signal one) will be reading voltage.
Connect the black to the black (ground), and the other hot wire connect to the positive end of your sidemarkers.
Old Dec 4, 2007 | 03:41 PM
bcpEG's Avatar
Hay guys also any info on how to make it stay on and blink
Old Dec 4, 2007 | 04:24 PM
* B A N N E D *
Default Re: (bcpEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bcpEG &raquo;</TD></TR><TR><TD CLASS="quote">Hay guys also any info on how to make it stay on and blink</TD></TR></TABLE> I think its the Red and Green wire on the corner lights. I forget, go to search and type in side marker wiring.
Old Dec 4, 2007 | 04:30 PM
ke98248's Avatar
Default Re: (PinoyDelSol)
To settle this once and for all:
There are two wiring options. USDM (Sidemarker only blinks when turn signal is on) or JDM (Sidemarkers stay on and blink alternately with the signal). Pull back the fender liner and remove the corner/parking light. There will be 3 wires going to the bulb. Tap into the corresponding wires for each blinking style.
USDM:
Tap into green(turn signal) and black(ground) wire.
JDM:
Tap into red(parking light) and green(turn signal) wire.
Old Dec 4, 2007 | 04:46 PM
Neebs's Avatar
^ Good info there.
Old Dec 18, 2007 | 03:02 AM
1jdmek's Avatar
Default Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">To settle this once and for all:
USDM:
JDM:
actually i think you might have that backwards....jdm=blink with signal,and dont stay on...usdm=didnt come with factory side markers...so all the ones you see are customised or have jdm fenders..but people wire them direct so that they stay on with your lights...
Old Dec 18, 2007 | 03:12 AM
1jdmek's Avatar
Default Re: (1jdmek)
any one correct me if im wrong
Old Dec 18, 2007 | 06:21 AM
CapnKrunch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmek &raquo;</TD></TR><TR><TD CLASS="quote">any one correct me if im wrong </TD></TR></TABLE>
You got it right
Old Dec 18, 2007 | 06:31 AM
jus_spooln_wicha's Avatar
Default Re: (CapnKrunch)
http://members.***.net/ninety2...r.htm
i did mine this weekend... turned out good..but this guys templates were great for location.. but the cut out was way off..i trimmed alot more off my fender to make my markers fit.. good luck
Old Dec 19, 2007 | 05:29 PM
eG6 driver3's Avatar
Default Re: (jus_spooln_wicha)
T-taps....
Old Dec 19, 2007 | 05:40 PM
EF_9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drg1989 &raquo;</TD></TR><TR><TD CLASS="quote">how do i wire the sidemarkers into the turn signals? is there a link that takes it step by step?</TD></TR></TABLE>
http://www.hondamarketplace.co...56801
CapnKrunch
12
Mar 9, 2007 09:45 AM
whiteej1
Sep 15, 2006 05:10 PM
Johnny76
May 29, 2004 01:56 PM
HONDA-2NR
Dec 24, 2003 08:04 PM
apexii
Mar 5, 2002 03:24 PM
