something let go, i need some help!
Old Dec 4, 2007 | 01:55 PM
Rhythmsnewsn's Avatar
Default something let go, i need some help!
i was driving slow in second gear and i go to take a right turn and all of a sudden my wheel started to jerk and spin really fast then my car just slumped to the left. so i get out to see what happened and my drivers side front tire is totally cocked to the left and i smell grease. so im looking around to see if anything broke but all i could find were some bearings i think, they were covered in grease so i just put them in a bag i had.
Heres a few pics i took just now to see what going on here, looks like my ball joint went, can anyone confirm this?
Old Dec 4, 2007 | 02:00 PM
Donkey85's Avatar
Default Re: something let go, i need some help! (Rhythmsnewsn)
ur missing the bottom castle nut and cottor pin holdingn the lower ball joint to the lower control aarm
Old Dec 4, 2007 | 02:01 PM
stunn'd's Avatar
wiggle the ball joint around, if it feels loose at all, then replace it... in fact you need a new rubber boot, so i would just replace the whole joint anyway, they're pretty cheap.
did the lower control arm disconnect like that when you were driving? it looks like the nut stripped the threads right off the end? pics are kinda fuzzy
Old Dec 4, 2007 | 02:16 PM
Default Re: something let go, i need some help! (stunn'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stunn’d &raquo;</TD></TR><TR><TD CLASS="quote">did the lower control arm disconnect like that when you were driving? it looks like the nut stripped the threads right off the end? pics are kinda fuzzy</TD></TR></TABLE>
yes, it disconnected while driving, and i also found these at the scene
Old Dec 4, 2007 | 02:30 PM
black0hatch's Avatar
haha same **** happened to me. the lower ball joint castle nut fell off cause there was no cotter pin in there. those other three things are the bearings inside your axle. you need a new axles and castle nut and hopefull the threads on the ball joint are saveable.
Old Dec 4, 2007 | 02:31 PM
90crxdriver's Avatar
those bearings are for the cv joint. and I say replace the lower ball joint and check the other ones just to be safe.
Old Dec 4, 2007 | 02:35 PM
Default Re: something let go, i need some help! (90crxdriver)
what peice is the CV joint? and how could they have fallen out like that?
Old Dec 4, 2007 | 02:42 PM
the cv joint is the end parts of your axle. what probably happened is the ball joint seperated wicht pulled out the axle or actually ripped the boot then they fell off. just get a new axle.
Old Dec 4, 2007 | 02:43 PM
stunn'd's Avatar
The inner joint is the bulky looking peice on the end of the axle shaft that plugs into the trans. The bearings fell out because the shaft pulled out when your steering knuckle decided to disconnet from the lower control arm. If the bearings are still good, I would just clean them up and reassemble the inner joint.
However, I would get a new ball joint
Old Dec 4, 2007 | 02:45 PM
Fuzzy Rhubarb's Avatar
Plus, make sure you got something to lock the bolt. It was ghetto, but I had to use a damn paperclip once!
Old Dec 4, 2007 | 03:20 PM
Default Re: (Fuzzy Rhubarb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuzzy Rhubarb &raquo;</TD></TR><TR><TD CLASS="quote">Plus, make sure you got something to lock the bolt. It was ghetto, but I had to use a damn paperclip once!</TD></TR></TABLE>
haha ya my girls hair clip things work too.
Old Dec 4, 2007 | 03:44 PM
Default Re: (black0hatch)
well the bearings look good to me but ill just get another axle instead of rebuilding it, however i cant say much for the castle nut or the ball joint. the castle nut is striped bad.
Old Dec 4, 2007 | 03:51 PM
Default Re: (Rhythmsnewsn)
ya same ****. like i said get another castle nut and try to save the threads on the ball joint. lucky for me only the bottom threads were messed up but i just used a die to clean them.
Old Dec 9, 2007 | 09:27 AM
does anyone know how to re-assemble the axle? i have the bearings right here but i have no idea how they go onto the axle.
Old Dec 9, 2007 | 09:43 AM
EF001282's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythmsnewsn &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to re-assemble the axle? i have the bearings right here but i have no idea how they go onto the axle.</TD></TR></TABLE>
save the frustration with rebuilding the axle yourself, just use it as a core and trade it in for a rebuit one, and replace the lower ball joint and castle nut and get a new pin too.
don't be stupid by being cheap, it isn't worth it in the long run. think about the safety of yourself, your passengers and others on the road.
Old Dec 9, 2007 | 09:56 AM
snowseeker's Avatar
Default Re: (EF001282)
Just take it to a garage before you kill someone.
Old Dec 9, 2007 | 11:35 AM
Phshorty's Avatar
more or less kill himself, ive yet to see a crx in an accident where the car it hit passengers were killed.
Old Dec 9, 2007 | 01:53 PM
de_sjiem's Avatar
yep... definitely replace the ball joint... we had ours go at 65 mph... the results weren't pretty... car is probably no good anymore. Not worth it for the cost of the part
EM2 Charlay
Honda Civic (2001 - 2005)
16
Mar 23, 2010 02:41 PM
supermansdx
Oct 10, 2009 05:13 PM
HKSuperSi
Suspension & Brakes
15
Feb 12, 2008 08:49 PM
Armed Ferret
Dec 7, 2002 01:14 PM
earl
Feb 28, 2002 11:33 AM
