Timing Belt Change Parts
i am about to order the parts and just wanted to check if i was missing anything here are the parts i got so far:
- Timing Belt: 14400-PT0-004
- Timing Balancer Belt: 13405-PT0-0004
- Power Steering Belt: 56992-P0A-J02
- Alternator/Compressor Belt: 38920-P0A-J02
- Water Pump: 19200-P0A-003
- Front Balance Shaft Retainer Kit: 06923-P0A-306
- Valve Cover Gasket Kit: 12030-PT0-000
- Timing Belt Adjuster (Tensioner): 14510-PT0-004
- Timing Balancer Belt Adjuster (Tensioner): 13404-PT0-004
- Timing Belt Adjuster Spring: 13407-P0A-000
- Timing Balancer Belt Adjuster Spring: 14516-P0A-000
- Hondabond High-Temp Silicone Gasket Sealant: 08718-0001 (Can't Find this)
is there anything else i need for the timing bet change thanks
i have a 1995 honda accord lx
looks like you have all the parts you need.
Looks like you pulled it off my write-up and double checked the numbers cause I see the valve cover gasket number has been changed to match your motor.
For the Hondabond, just go into your local dealer and buy it there.
Now do you have the tools required to do the job?
yea great write up. gonna take it to the shop once the parts come in
whats the best place to buy parts online?
Majestic Honda told me $289 for all the parts shipped
what about the
cam seal: 91213-PT0-003
balancer seal and holder: 91233-PT0-003 (Seal)
oil pump drive seal: 15116-PT0-306
crank seal: 91212-P0A-004
do i need these or are they optional?
Modified by ali7up at 10:42 AM 12/5/2007
oh yeah, sorry, those should be on the list as well. With exception to the "oil pump drive seal", not sure why you would need to replace then unless you were having problems.
They are cheap and if you dont replace them and they go then you have to tear it all back apart. Best to just replace them now.
yes thats was what i was thinking, they are like $10 more plus the balance holder is the same thing as the Front Balance Shaft Retainer Kit, they both have the same part number
chandlorexia
Oct 12, 2012 06:40 AM
chandlorexia
Engine Management and Tuning
Oct 11, 2012 10:44 AM
BlitzSix
Feb 16, 2009 02:47 PM
doostin
Feb 1, 2009 04:45 PM
06923p0a30, 06923p0a306, 06923p0aj02, 13405pt00004, 13407p0a000, 2002, accord, balance, belt, change, component, front, honda, kit, parts, retainer, shaft, timing
