Spring Rates for Integra Ground Control Limited Edition?
Old Jun 26, 2002 | 08:34 AM
CivicNewbie's Avatar
Default Spring Rates for Integra Ground Control Limited Edition?
Anyone knows what are the spring rates of the Integra GC Limited Edition?
TIA.
Old Jun 27, 2002 | 02:11 PM
Default Re: Spring Rates for Integra Ground Control Limited Edition? (CivicNewbie)
Old Jun 27, 2002 | 11:23 PM
Balrog's Avatar
New User
get custom rates. i have the same setup you do. and i have 400fr/450rear.
wieght transfer is bad!
tight turns good!
Old Jul 10, 2002 | 05:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: Spring Rates for Integra Ground Control Limited Edition? (Balrog)
Ground Control told me the spring rates on the normal coilover kit are 350F/280R. Not sure if the limited edition is any different. Do you think 350F/280R will be stiff enough for the street and autocrossing?
Old Jul 10, 2002 | 09:35 AM
qbsi's Avatar
Default Re: Spring Rates for Integra Ground Control Limited Edition? (Muckman)
you might wanna go a bit more stiff on the back.
Old Jul 10, 2002 | 10:57 AM
Muckman's Avatar
Moderator in Chief
Default Re: Spring Rates for Integra Ground Control Limited Edition? (qbsi)
Yeah im going with 500f/400r. Stiff but not too extreme...
Ground Control Limited Editions. Had to call CG anyways so I asked them about the limited editions. And the guy I spoke with said "The Limited Edition where made to fit alot of shocks & I believe they are also the same for the civic & the integra so they where able to build alot of kits to fit the same vehicles & not offer them to be changed (cant change the spring rates & heights) so they where able to discount the price. "
So I would assume that the spring rates would be the same as the normal kit - 350f/280r.
dumpedEK4
Jul 29, 2014 02:31 PM
sting94112
Feb 12, 2004 05:05 AM
Acronym
Sep 18, 2002 03:13 AM
743power
Mar 20, 2002 07:25 PM
