PR3 chipped....wat chip do i have?
Old Dec 3, 2007 | 11:27 PM
crx_si-r's Avatar
Default PR3 chipped....wat chip do i have?
ok i just bought a JDM PR3 ECU on craigslist for $30. and the guy said he bought it with the car, but the ecu is socketed and chipped with an unlabeled chip. is there any way to tell with the numbers on the chip wat kind of chip it has? i will be postin pics of it in a few mins. thanks
Old Dec 3, 2007 | 11:45 PM
crx_si-r's Avatar
Default Re: PR3 chipped....wat chip do i have? (crx_si-r)
the numbers on top of the chip are as follows.....
M38256AP-93
OKI
JAPAN 0923G
pics are loading and will be up in a few seconds.
here are the pics....top side
bottom side...
Old Dec 4, 2007 | 01:24 AM
ef yu's Avatar
datalogging.
Old Dec 4, 2007 | 05:41 AM
Furyof4's Avatar
Default Re: PR3 chipped....wat chip do i have? (ef yu)
Thats just the stock chip put into a socket.
Old Dec 4, 2007 | 06:25 AM
crx_si-r's Avatar
Default Re: PR3 chipped....wat chip do i have? (Furyof4)
the stock chip huh? oh well still not bad for $30 right??? well now, here is my next question.....where can i purchase some reputable chips for my ecu? i kno there is ebay but i want some good stuff? thanks again.
Old Dec 4, 2007 | 07:20 AM
Furyof4's Avatar
DO NOT Buy an Ebay chip!!! There are all **** copies of basically stock maps with more fuel, timing, random vtec X-overs and ridicuosly high rev limits.
Go to someone who will burn you a base map in BRE to get it running, and then get atleast a street tune to make sure your running safe. No basemap or "chip" will run your setup perfect.
Old Dec 4, 2007 | 08:19 AM
crx_si-r's Avatar
in order to have a chip burned for what i need, would i have to take my car in to a shop and have them run the dyno and then set my new maps? even if its a basic LS Vtec for right now? i mainly just want my knock sensor disabled. if i do have to take it in does anyone in northern cali know of any good shops?
Old Dec 4, 2007 | 09:58 AM
ef yu's Avatar
where are you located in norcal?
Old Dec 4, 2007 | 10:09 AM
crx_si-r's Avatar
im in sacramento. so anything near here that does a good job would work.
Old Dec 5, 2007 | 08:31 AM
crx_si-r's Avatar
well i found out today that it is a stock chip. mainly because i drove on it for about 10 minutes and got a code 23 (knock sensor) . it acted just like my other virgin PR3 and my other 2 virgin PW0's. so at least i know that the ecu and chip both work. lol
Old Dec 6, 2007 | 05:24 AM
dabigshmo's Avatar
u should try John Kerr at http://www.j-k-tuning.com he chipped my ecu he does good work.
Old Dec 6, 2007 | 07:05 AM
crx_si-r's Avatar
Default Re: PR3 chipped....wat chip do i have? (dabigshmo)
they only do obd1 im running an obd0 ecu
Old Dec 6, 2007 | 07:11 AM
Furyof4's Avatar
Not true. John tuned my obd0 car on BRE. He's on the other side of the country from you but I can vouch for his work.
Anyone that is familiar with crome will most likely do BRE too.
Old Dec 6, 2007 | 08:22 AM
crx_si-r's Avatar
i checked the site and could only find obd1. ill double check and see.
Old Dec 6, 2007 | 09:09 AM
Furyof4's Avatar
Its not listed on his site but he'll most likely help you out if you email him.
Old Dec 6, 2007 | 10:11 AM
crx_si-r's Avatar
i emailed him earlier with wat i wanted and if he could help me out. im just waiting for his reply. thanks guys ill keep u posted
Nick97hatch
Engine Management and Tuning
Mar 13, 2011 08:00 AM
WeB
Jan 19, 2010 11:17 AM
90turbointegra
Aug 12, 2009 11:20 PM
Metal Typhoon
Jul 26, 2006 01:21 PM
xDicktonesx
Jun 23, 2005 02:24 PM
