fuel regulator or blox mani-maybe reason for weak b18c1 in da9?
Old Dec 3, 2007 | 08:35 PM
be18see1's Avatar
Default fuel regulator or blox mani-maybe reason for weak b18c1 in da9?
i have a b18c1 swapped da9, and the engine feels like its running out of air or fuel. when i get up to 6-8k, the motor is screaming but the power i expect just isnt there. when i did my swap, i used the fuel reg off of a h23 bc the barb aimed a better direction for my fuel lines-is this more restrictive than than the original one. i also have a blox mani and have not had it tuned. which of these would be a more likely candidate?
for reference-i was able to get my car on a closed circuit at the police academy and it sort of stopped accelerating at 110 mph. this was at ~7 or 8k in 4th gear. i did the same thing with my gsr and i made it to like 125+. this is the same motor. it also throws a fuel injector code as well, so i wonder if it is the actual injectors or the regulator. thanks in advance!
Old Dec 4, 2007 | 06:50 AM
be18see1's Avatar
Default Re: fuel regulator or blox mani-maybe reason for weak b18c1 in da9? (be18see1)
ttt
Old Dec 4, 2007 | 07:02 AM
GRAF-FITI's Avatar
* B A N N E D *
if it's throwing a fuel related code, i would assume that might be your issue
start with the regulator (it's cheaper than buying 4 new injectors)
i would do that and then the injectors if the code hasn't dismissed, then get it tuned
Old Dec 4, 2007 | 07:33 AM
be18see1's Avatar
Default Re: fuel regulator or blox mani-maybe reason for weak b18c1 in da9? (GRAF-FITI)
on the issue of tuning, do i have to fork out the $$$ for hondata or cromoe, or can i get it chipped to do the same thing? ive never had anything tuned, and some of my friends insist that i have to get hondata crome ectune etc. can someone point me in the right direction?
Old Dec 4, 2007 | 07:35 AM
GRAF-FITI's Avatar
* B A N N E D *
get CROME
chips are ok if:
1. the person setting them up knows what they are doing
2. they are specific to your indivdual setup
Old Dec 4, 2007 | 08:06 PM
be18see1's Avatar
what does crome cost to set up, not including the actual tune?
or... how much would getting a chip cost?
im just looking for rough numbers.
Old Dec 5, 2007 | 09:50 PM
be18see1's Avatar
ttt for the last question i have..
4sily
Apr 6, 2012 09:49 PM
tr0n9h
Oct 30, 2005 01:33 PM
cincispeedemon
Nov 22, 2004 05:51 PM
im a monster hehe
Feb 20, 2004 09:45 PM
TurboB18C1
Apr 17, 2002 09:27 AM
