pressure plate gone? cant move out of neutral
Old Dec 3, 2007 | 07:11 PM
Lordofdark176's Avatar
Default pressure plate gone? cant move out of neutral
alright so im crusin down the highway, went to downshift to pass someone and it got stuck in neutral, wouldnt budge. so i pull over and popped the hood to see if its just low on fluid, fluids fine, selects gears fine with the car off, and with the car off if i press the clutch down the shift fork is still moving its full path. Bled the clutch, got alot of air out but no difference. if i started teh car with the clutch in and in gear, it would just start moving in whatever gear i was in. i managed to limp home by waiting till there was an opening in traffic, putting it in 1st with the car off and starting it and just going as fast as i could, i was able to shift without the clutch (rpm matching) to get home. This clutch has been in this motor for 6 years and has seen its fair share of abuse by me, and the previous 2 owners. is the pressure plate dead? clutch dead? both? or is it just the master or slave cylinders or both? input please!!!
Old Dec 3, 2007 | 07:14 PM
crxricer66's Avatar
Default Re: pressure plate gone? cant move out of neutral (Lordofdark176)
is your master cylinder or slave cylinder leaking?? possibly throwout bearing. gl
Old Dec 3, 2007 | 07:15 PM
no leaks anywhere. i did notice earlier today though that it was shifting really shitty, like hard to engage each gear and would sometimes grind, when it didnt do this yesterday. I didnt think any of it though. bump for more input!
Old Dec 3, 2007 | 07:19 PM
DCSportEJ1Civic's Avatar
Default Re: (Lordofdark176)
pull the boot back and check if the clutch fork is actaully moving. it sounds like the clutch is grabbing fine, just not disengaging right?
electron_si's Avatar
what year is the car, is the clutch stock?
have you had problems with rpm climbing when going up hills or on highway, or has the clutch been slipping when taking off from a light?
Old Dec 4, 2007 | 02:21 AM
Default Re: pressure plate gone? cant move out of neutral (electron_si)
ls/vtec motor, b18b1 block, b16 head, gsr trans, exedy stage 2 race clutch. no problems with the clutch slipping. any more ideas?
Old Dec 4, 2007 | 11:19 AM
bump
Old Dec 4, 2007 | 11:22 AM
97Ej6mike's Avatar
6 years of abuse is too much.
Replace it, end of story.
Old Dec 4, 2007 | 11:28 AM
vandersmissenc's Avatar
Default Re: (97Ej6mike)
i had that same chain of events happen and i had snapped my pressure plate in 2. But i was also in really high rpm's when i down shifted (B16) . So that sounds like how i had to get home as well. My guess is pressure plate like you said.
Old Dec 4, 2007 | 11:31 AM
AWD Terror's Avatar
Default Re: (vandersmissenc)
Pressure plate
Old Dec 4, 2007 | 11:33 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (AWD Terror)
If its a sprung clutch, I'm willing to bet that one or more of your springs is crushed or missing completely. New clutch time for sure.
Old Dec 4, 2007 | 12:00 PM
update:
took a video of what the slave cylinder looks like when i depress the clutch pedal, does it look like its traveling its full path?
http://youtube.com/watch?v=D-YYXfMdpHM
Also i noticed this morning after the car sat all night the clutch pedal fells really soft, i did bleed it last night but it was stiff last night. no puddles under my car from leaks (only from where i spilled the bleeding bottle once) but no leaks dripping from the master or slave cylinders. ideas?
Old Dec 4, 2007 | 12:58 PM
bump
Old Dec 4, 2007 | 02:07 PM
EG6-baybee's Avatar
Funny thing, this just happened to me on the 10 freeway. I down shifted and it got stuck in neutral so i pulled over checked everything, everything was good. I did the same started it in gear and just rpm matched it all the way home. pulled the motor out ( I was gonna do this anyways) and one of the legs on the bearing was broken. changed, and worked fine again after that!!!!
Gooduck with it. Hopefully my info has been of use!!!!
Old Dec 4, 2007 | 06:06 PM
which bearing?
Old Dec 4, 2007 | 06:55 PM
DC2Projektz's Avatar
Default Re:
i'm almost positive its the pressure plate. same thing happened to me. i changed out the clutch and the pressure plate on my old clutch was completely used up, change out the clutch!
Old Dec 4, 2007 | 09:14 PM
blue_hatch's Avatar
Default Re: Re: (DC2Projektz)
if theres theres pressure than its not your pressure plate probably your clutch disc
Old Dec 4, 2007 | 09:19 PM
EG6-baybee's Avatar
Default Re: Re: (blue_hatch)
Either way your gonna have to drop the tranny to fix whatever it is so take it off and it should be obvious what the problem is!!!
91SI92
Apr 23, 2011 11:44 PM
ch0baca
Mar 11, 2009 02:11 PM
JDM_SOHC
11
May 9, 2007 10:52 AM
2wheelhunter
Aug 30, 2006 07:56 PM
dragon_rev
Mar 27, 2004 03:21 PM
