Ys1 cable tranny what axles? 96 hatch
Old Dec 3, 2007 | 06:56 PM
BWek's Avatar
Default Ys1 cable tranny what axles? 96 hatch
hey guys i have an avid kit to put my ys1 in my car and was wondering waht axles do I run? i know the half shaft is different from a hydro tranny
Do i run 90-93 integra axles?
its a 96 hatch
Old Dec 3, 2007 | 09:09 PM
watsvtecEK's Avatar
Default Re: Ys1 cable tranny what axles? 96 hatch (BWek)
What intermediate shaft will you be using?
Old Dec 3, 2007 | 09:27 PM
BWek's Avatar
Default Re: Ys1 cable tranny what axles? 96 hatch (watsvtecEK)
Can i use Just any kind? i don't have one yet can Do i need to use one from a 90-93 integra or 94-01 integra I know they are different I have access to both I haven't bought the halfshafts or cv shafts what the best/easiest soloution?
Old Dec 4, 2007 | 08:10 AM
saleensolution's Avatar
the pass side there is no difference unless you have ABS, but if you are you using the 90-93 integra half shaft you dont have to do anything, but if you use a 94+ integra half shaft you have to change the axle seal on the driver side of the tranny.
good luck
Old Dec 4, 2007 | 06:49 PM
SEATownboi08's Avatar
use 90-93 axles=P
Old Dec 5, 2007 | 05:25 PM
BWek's Avatar
So if i use a newer half shaft (which i assume will be easier to get) just pop the old seal out and get a new seal from a hydro tranny
And any integra axes will work I do not have abs
Also my car is an automatic at the moment the hubs are the same right? i know the older cars the hubs had to be swapped
thanks for all the help guys
Old Dec 6, 2007 | 03:42 PM
BWek's Avatar
anyone?
Old Dec 7, 2007 | 05:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BWek &raquo;</TD></TR><TR><TD CLASS="quote">So if i use a newer half shaft (which i assume will be easier to get) just pop the old seal out and get a new seal from a hydro tranny
i dont think you have abs, no you dont have to change hubs, and yes you just have to change the seal if you use newer axles
kp
May 12, 2009 10:40 AM
.Grimace
Sep 29, 2005 08:28 AM
Ransom
Apr 8, 2004 02:27 PM
chirp2hrd
May 20, 2003 06:59 AM
paulzy
May 13, 2002 09:04 PM
