3rd Brake Light Removal
Old Dec 3, 2007 | 06:41 PM
GStone899's Avatar
Default 3rd Brake Light Removal
I have a 99 Accord and I would like to know how to remove the 3rd brake light (or to be more specific, the black piece that goes around the brake light). It is a tight spot back there and there is some debris that has gotten behind the brake light. Any help would be great!
Old Dec 3, 2007 | 07:12 PM
doubleecho's Avatar
Default Re: 3rd Brake Light Removal (GStone899)
are you talking about the one above the rear passenger seat?
Old Dec 3, 2007 | 08:03 PM
The-Kid's Avatar
Default Re: 3rd Brake Light Removal (doubleecho)
If I'm not mistaken. There are 2x 10mm nut holding the 3rd brake light down inside the trunk area. They should be side by side. It might be hard to reach, but i know they are. Remove the 2 nuts. and remove the 3rd brake light front inside the car.
Old Dec 4, 2007 | 07:18 PM
GStone899's Avatar
Default Re: 3rd Brake Light Removal (The-Kid)
Thanks The-Kid, I will try that. And yes, it is the light behind the backseat.
Old Dec 5, 2007 | 06:19 PM
02 accord's Avatar
There are no screws. It's held in by clips. Open the trunk, and look for 4 clips sticking through. Push 2 of those out of the way to release, and push up on the light.
Old Dec 5, 2007 | 09:37 PM
The-Kid's Avatar
Well IDK. it might be different on the 6th gen Accords. Because the lamps are not as long as the 5th gens. I will check too on my 01 Accord. Sorry if I gave the wrong info. I usually work on my 96 more often.
Old Dec 6, 2007 | 09:10 AM
GStone899's Avatar
Alright. I will look for some clips. I am going to do this today so I will be in touch. Thanks for the help so far.
MDM
Mar 8, 2012 08:12 PM
bobmugen
Jan 11, 2008 11:17 PM
FalconMan
Jan 28, 2003 09:21 PM
