cause ????? effect too lean or too rich
Old Dec 3, 2007 | 06:11 PM
ekhatchey's Avatar
Default cause ????? effect too lean or too rich
what would cause my engine to run too lean or too rich?????
Old Dec 3, 2007 | 06:12 PM
DCSportEJ1Civic's Avatar
Default Re: cause ????? effect too lean or too rich (camarine2003)
usually a bad O2 sensor
Old Dec 3, 2007 | 06:13 PM
Padawan's Avatar
Darth ModerVader
How do you know it's running too lean or too rich?
Old Dec 3, 2007 | 06:15 PM
ekhatchey's Avatar
check engine light code......
Old Dec 3, 2007 | 06:34 PM
ekhatchey's Avatar
could a really dirty air filter cause this ?????
Old Dec 4, 2007 | 05:39 AM
ekhatchey's Avatar
morning bump
Old Dec 4, 2007 | 06:04 AM
ivannaciv's Avatar
I dont not beleive so. what mods do you have done?
Old Dec 4, 2007 | 07:48 AM
mortificationrock's Avatar
Default Re: (ivannaciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivannaciv &raquo;</TD></TR><TR><TD CLASS="quote">I dont not beleive so. what mods do you have done?</TD></TR></TABLE>in for some info or toughts of this!
Old Dec 4, 2007 | 08:08 AM
JDM_teh_WIN!!'s Avatar
Default Re: (mortificationrock)
If someone took a **** in your intake that could do it.
Old Dec 4, 2007 | 08:37 AM
King V's Avatar
Default Re: (JDM_teh_WIN!!)
Too rich can be caused by a clogged air filter or sticky/shitty injectors or a hole in the FPR diaphragm. Too lean can be caused by vacuum leaks or a weak fuel pump, for a couple examples.
Old Dec 4, 2007 | 08:50 AM
oneiro's Avatar
Did you add a FPR, changed your injectors, O2 took a ****, changed your ECU to some custom ebay chip? What's the setup?
Old Dec 4, 2007 | 07:14 PM
ekhatchey's Avatar
cold air intake that all right now
Old Dec 4, 2007 | 08:57 PM
H-EK22's Avatar
Default Re: (camarine2003)
Do a full tune up, and clean the injectors an change the air filter(just in case), an make sure the 02 sensor isn't bad....if that doesnt solve the problem could be something major
HondaMan2380
Sep 21, 2010 03:39 PM
BB4vTak
Sep 2, 2009 11:20 AM
Shonn
Oct 16, 2006 04:29 AM
SICKSOLSI
Jul 27, 2004 10:15 PM
