Resolder rear ABS lines?
Old Dec 3, 2007 | 05:50 PM
pearl's Avatar
Default Resolder rear ABS lines?
I know, its crazy. Don't ask. I'm kind of upset about it too.
I hacked up the lines on the rear abs lines. The ABS light is obviously on. What are my options for making it go away? I'd like to thing I can solder them, but I think they might be too fussy of a sensor to resolder.
Has anyone else done this?
Old Dec 3, 2007 | 05:52 PM
IMALLSLO's Avatar
Default Re: Resolder rear ABS lines? (pearl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearl &raquo;</TD></TR><TR><TD CLASS="quote">I know, its crazy. Don't ask. I'm kind of upset about it too.
Has anyone else done this?</TD></TR></TABLE>
Replace and be done with it. You f'ed up...consider it a lesson learned. Wouldn't try soldering it. .
Old Dec 3, 2007 | 06:06 PM
pearl's Avatar
Default Re: Resolder rear ABS lines? (IMALLSLO)
damn. i cant find a part number either.
Old Dec 4, 2007 | 12:43 PM
dwolsten's Avatar
I hacked up the lines on the rear abs lines. The ABS light is obviously on. What are my options for making it go away? I'd like to thing I can solder them, but I think they might be too fussy of a sensor to resolder.</TD></TR></TABLE>
Soldering will always work (the sensor and electronics can't tell the wire has been soldered); the problem is longevity. You'd have to do a very good job resoldering the wires, and then protecting them with heat-shrink tubing with an internal adhesive coating so that moisture doesn't get in there and corrode the wires.
I'm not that familiar with the ABS wires going to the sensors; do they have one wire inside, or two?
The best and easiest option is just to replace them, obviously. But if that's too expensive, you can solder them, as long as you wrap them up properly.
Old Dec 4, 2007 | 12:48 PM
pearl's Avatar
Default Re: Resolder rear ABS lines? (dwolsten)
Thanks for the unput. It is one wire. Its so cold, I need to find a garage to test this out in.
Old Dec 4, 2007 | 01:33 PM
Dogginator's Avatar
Daisy... Daisy...
See my signature for part number links. Soldering that harness will be difficult since the wires are encased in rubber.
Old Dec 4, 2007 | 02:16 PM
IMALLSLO's Avatar
Default Re: Resolder rear ABS lines? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote"> Soldering that harness will be difficult since the wires are encased in rubber.</TD></TR></TABLE>
Thus the reason I said to just replace it
Old Dec 4, 2007 | 02:31 PM
pearl's Avatar
[QUOTE=DogginatorSoldering that harness will be difficult since the wires are encased in rubber.[/QUOTE]
I already sliced it in half, so it wont be too bad
Old Dec 4, 2007 | 05:42 PM
dwamp2006's Avatar
if your feelin lucky just get a line end bend it yourself
Old Dec 4, 2007 | 05:45 PM
pearl's Avatar
Default Re: (dwamp2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwamp2006 &raquo;</TD></TR><TR><TD CLASS="quote">if your feelin lucky just get a line end bend it yourself</TD></TR></TABLE>
its a wire.
Alcatrax30
Aug 30, 2014 06:42 PM
c1_sleeper
Suspension & Brakes
Oct 16, 2008 07:10 PM
JDMCRX
May 28, 2008 06:45 PM
Boosted00GSR
Jan 22, 2006 06:18 AM
