I am clueless but I need to know the best tire size for the dragstrip
ok well I have decided to go with Diamond Star Racing wheels to use with slicks, my question is what is the proper size to use? What offset and what size should I send to make that would go good with M/T or something
There is a topic stickied at the top of this forum:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING »</TD></TR><TR><TD CLASS="quote">
<FONT SIZE="4">Rules</FONT>
4. When starting a topic, make the title specific enough that people scanning the list of forum topics will know what's inside. "Need help" or "have a question" are not specific enough. We will rename threads in ways that you might not like. If you violate this rule, we will call you a clueless tool who didn't bother reading the FAQ topic stickied at the top of this forum.
Which is why it's been changed from "need some help.....". You clueless tool.
It says:
I am no race or tire guru, but when you ask for a custom grind cam, some of the info they ask is what is your gear ratio and tire size and many things. I am going to say before you spend the big bucks on some really good tires that you experiment. Altimetely, everyday scearios come into play and the track conditions also, so I am guessing you are just looking for a GENERALISTIC answer since you did not build your car around your tires, but If you want to build your tires around the car then we need much more info.
DunkJDM
Dec 3, 2007 07:47 PM
near495
Nov 30, 2007 05:52 AM
