please help
Old Dec 3, 2007 | 05:09 PM
northemt88's Avatar
Default please help
hey i have 1991 civic h/b with a b18a1 swap i am burning oil it only burns oil at high rpms/wop if i daily drive it its fine.we did a valve adjustment that wasent it,do you think i should change my pistons and rings?also its 91 block on a 92 head,i also dont think its the head gasket because im not loosing any coolent.
thanks for looking
Old Dec 3, 2007 | 05:13 PM
jwbnavy's Avatar
Default Re: please help (northemt88)
It's an old engine could be a lot of things, but if I were to guess it would be rings. Maybe time for a rebuild or keep adding oil to keep it running to save for another.
Old Dec 3, 2007 | 05:19 PM
northemt88's Avatar
Default Re: please help (jwbnavy)
cool so you think if i get new rings and pistons that should help right?
Old Dec 3, 2007 | 05:25 PM
jwbnavy's Avatar
Might as well do a rebuild at that point.
jwbnavy's Avatar
How much oil is it burning anyway?
Old Dec 3, 2007 | 05:45 PM
Fuzzy Rhubarb's Avatar
replace your PCV valve. mine had the same problem, replaced that, fixed the smoke!
Old Dec 3, 2007 | 06:02 PM
northemt88's Avatar
Default Re: please help (Fuzzy Rhubarb)
if im wop i got to fill it with half a quart every 2 day
Old Dec 3, 2007 | 06:04 PM
northemt88's Avatar
so you dont think its the rings,also is the pcv were the black box next to the oil filter?
Old Dec 3, 2007 | 06:08 PM
Fix that PCV valve, its like 5 bucks. Its a hell of a lot easier/cheaper than replacing the rings.
Old Dec 3, 2007 | 06:10 PM
northemt88's Avatar
where is it located
No, its in between the runners. look for a little 90 degree bend and a big hose that goes to the IM.
not quite a B, but close enough
Old Dec 3, 2007 | 06:17 PM
northemt88's Avatar
thanks also what is the pcv valves job how does it help burning oil
Old Dec 3, 2007 | 06:19 PM
It prevent pressure from building up in the crankcase and stop blow-by. That's when gasses and oil blow across the rings and get burn up causing smoke.
Old Dec 3, 2007 | 06:21 PM
northemt88's Avatar
thanks alot i let you know what happens
Old Dec 3, 2007 | 06:23 PM
GL
lsvtechatchy
Apr 4, 2011 09:10 AM
crampinyourstyle
Mar 11, 2011 12:50 PM
Autointeg
Sep 26, 2009 11:06 PM
VvPeachyvV
30
Nov 29, 2005 04:42 PM
quik1
May 17, 2004 07:15 PM
