my e brake is stuck... i think
well its night time so i cant check it right now so yeah....(apartments)
my brake light will not turn off. i think my e-brake might be jammed a little i can still drive but i can tell that its rubbing. ive never taking apart the ebrake before so i dont know what to do. does it need to be tighten(how? if so) or could my brake fliud be doing it and not releasing the brake all the way(even though its cables guided) because it might be low, ill check tommorow but im doubting its that
......i drifted once but nothing happened until yesterday and i drifted about 3 weeks ago. also does weather maybe have something to do with it?
First off an FF is not meant for drifting u dumbass! Buy an FR!
As far as your light goes, make sure the e brake is down all the way. if so and the light is still on, take the center console off and see f the wire for the light has come off the switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">First off an FF is not meant for drifting u dumbass! Buy an FR!
As far as your light goes, make sure the e brake is down all the way. if so and the light is still on, take the center console off and see f the wire for the light has come off the switch. </TD></TR></TABLE>
FF? FR? Can you clarify?
no its not loose i just check. could i be the actual brakes themselves? the lines are tight, the wires are tight. what coud be wrong!!!! i hate seeing this damn light when i drive. and like i said the light isnt just on the brakes themselves are rubbing and ive never takin apart the ebrake before so if someone can explain what to check that'd be nice......noob i know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djessenz »</TD></TR><TR><TD CLASS="quote">
FF? FR? Can you clarify?</TD></TR></TABLE>
he meant front wheel drive rear wheel drive. my eg is front wheel drive and i drifted with it.
first off expletive anyone that turns this thread into a what is and is not drifting. thats so annoying and unsessary
OP: if you have an automatic trans and you dont use the ebrake often the cable could be rusted and frozen. or because of cold weather it could be wet and frozen. those are the two most common things i can think of other than a problem with the brakes themselves.
ismellskunk
Jun 4, 2006 02:35 PM
ham_yorkwind
Apr 10, 2005 07:43 PM
BigZ88
Feb 21, 2005 09:17 PM
